Virtual Channel not transitioning to next episode
Installed 2 Virtual Channels (Friends & The Big Bang Theory) as my family will have that on the background whenever nothing else is on. I used Ripped Blue Ray MK4 files and they play fine, however when the episode ends, it doesn't launch the next episode, it just has a black screen. If I hit back, go back into the guide and select Virtual Channel, it works fine, but it won't transition from one episode to the next.
Anyone else having this issue?
Thanks.
What platform? Did you submit diagnostics after this happened?
Please provide these as we need more information to help.
Of course when I try and recreate it, now they are transitioning with no problems. For future reference, should I send the diagnostic from the client, server or both?
Server = Linux Workstation (2022.02.09.0020)
Client is NVIDIA Shield and TV with Google TV built in. Both are 4.2.0
OK, did it again. Submitted logs (both server and client) around 11:30 EST. Here's the Server Log number: b7453218-0fe9-45ea-8520-30a38f2b7fc9
