I recently moved to Beta version 2023.04.27.2253 in order to implement Streamlink and now my virtual channels do not work. Is this a known issue? What are my alternatives to fix it?
Thanks.
Thanks.
Please be specific, what is the behavior you're seeing?
Does reload the guide help?
Does the log show any errors? Does it show guide data loading for X-VIRTUAL?
The guide was not showing any content. Refreshing did the trick. Thanks for your help and sorry for the fire drill.
