Virtual channels on Android
Hello.
My issue with virtual channels on Android beta is that once a show is over, it doesn't play the next episode. It just stays at an empty black screen. I don't have this issue on my iPad.
Any ideas?
Thank you.
What decoder are you using? The next episode might be in a different format. Try software or hybrid if you aren’t already and see if the issue goes away.
Thanks! I changed my setting from hybrid to software and it seems to have worked.
