I went back to July 8 and it’s working much faster on that build
@tmm1
I still see the daily show popping up but it’s much more quicker basically back to normal I would say on that build
@tmm1
That's pretty far back, if you are able to put in the time to test different builds to see if you can find which build it starts on, that would go a long way in discovering what the issue might be.
Thanks for looking!
Sounds good will let you know!
Funny enough on build 7.19.153 is where I get issues.
7.8.2249 is the last time it works properly
Thanks guys!
7.8.24 is the fastest I would say by milliseconds
@maddox @tmm1 do you think this will have to be something resolved just on my side or is it more an wide update or something?
Hey Guys just following up on this.
I was able to narrow it down to build 7.19.153 where the issue starts, with 7.8.2249 being the last version that worked properly. Unfortunately, that 7.8 build has now expired, so I can’t roll back to it anymore.
Do you think this is something that’ll likely be resolved in an upcoming update, or is there anything I could try on my end in the meantime?
Thanks again for checking into it!
Great!, we'll look into it soon.
Can you try the current App Store version and see if you have the same bad results?
Will do tonight. Thanks!!
Blazing fast! Thanks Guys!
Sick! Thanks for bringing it up!
