Virtual Channels won't work in Web
It does let you select video groups for a Virtual Channel, just like selecting them for a Library Collection you need to scroll all the way down past all your TV Shows and Movies to find the Video groups.
I just created a Virtual Channel with some video groups, but can't figure out how to play the channel from the web UI (guess you can't).
Virtual Channel playback is a client only feature.
Thanks, that explains the errors in the log.
[ERR] Failed to start stream for ch10001: Virtual channels are not supported
[HLS] Couldn't generate stream playlist for ch10001-dANY-ip172.18.0.1: Virtual channels are not supported
[HLS] Stopping transcoder session ch10001-dANY-ip172.18.0.1
Did it give you the option to play it back in web? It shouldn’t have even done that. :thinking:
My Virtual Channels are showing up on the web, under the main Custom Channel I use...
When clicking on the airing to get the Watch button, it should not show. Can you provide a screenshot?
They certainly show up, but I didn't try to watch. I will try in a moment.
edit.
They show up with no option to play.
Yes they show, but you can't watch.
Correct. Not sure how @chDVRuser was able to get as far as he did?
Live TV > On Now and Filter to Virtual Channel
I have 5 virtual channels and one of them has the play option, using the location you posted, the other 4 do not.
