Volume in beta 8.2.109 lower than release 1.5.3
Audio volume in the latest beta is lower than in the current 1.5.3 general release. I’m not sure if this is intentional or not, but I did notice that when i switch from a different source to watching TV through the beta, I had to turn the volume up quite a bit. I then flipped between the beta app and the release app via multi-tasking and it was pretty clear that the beta is lower.
We made some changes to the audio decoder, so this must be related. I think the new volume is technically more correct… in that it should match the volume levels in other apps on the ATV.
Oh alright. I just played some video from a few more apps (ESPN, HBO GO, NBC Sports and ABC) and it isn’t as large a difference as it originally seemed. Seems just a hair more quiet, but I’d probably have to drag out a decibel meter to measure the difference for sure. Not going to do that!
I noticed this as well when comparing with other apps, Channels output sound is much lower than the rest.
