Way to run in background
Is there a cli flag to run as a daemon on Linux embedded devices? I had been running with cron but that does not work now. Also can app be updated to have separate streaming levels for SD and HD sources like the web player. My device is rt-ax56u and is arm powered.
Running on routers is not supported.
Ya know...indeed, many high end routers have decent CPU's these days.
On par with the things like the RPi4.
Even have USB 3.0 ports.
However, i do not think routers have any sort of GPU in them, so any video decoding would have to be CPU only. The CPU doing everything for Channels server, and being a router with wifi AP.....easy to overload.
As tmm1 already states, routers are not officially supported for use with Channels DVR server....so if you have managed to to get it working in some fashion, you are on your own and the devs will not be able to give any support.
