Will Channels run on the above NAS? Will it transcode? In general, how will it work/not work?
Thanks
It will work for recording up to a couple shows at a time. It can transcode one stream at a time. Commercial detection will take several hours. If you try to record, transcode and commercial detect at the same time, things will be slow and might fail.
Thanks for the quick reply. I’ll stick with I5 pc which works just great and fast.
