Hi, I am getting a weak signal message even though I am using a cablecard connection on a wired 1Gb network. Any ideas.
Click on your hdhomerun on http://my.hdhomerun.com and check the tuner status signal strength. If you’re using a splitter with your cable before feeding it into the HDHR, it might be why.
