2018/03/07 20:05:24 [HLS] Starting transcoder for file593-b61fb4b180cd at 0s from 81.152.190.1 (encoder=remux, resolution=, deinterlacer=, bitrate=10000)
[h264 @ 0x7f9b61801600] mmco: unref short failure
[mpegts @ 0x7f9b61009a00] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x7f9b61009a00] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 0x7f9b61009a00] Dropped corrupted packet (stream = 2)
[mpegts @ 0x7f9b61009a00] Could not find codec parameters for stream 2 (Audio: aac_latm ([17][0][0][0] / 0x0011), 0 channels, fltp): unspecified sample rate
Consider increasing the value for the ‘analyzeduration’ and ‘probesize’ options
Too many packets buffered for output stream 0:1.
[aac @ 0x7f9b60828a00] 2 frames left in the queue on closing
2018/03/07 20:05:31 [HLS] Stopping transcoder session file593-b61fb4b180cd @ 0s
2018/03/07 20:05:37 [HLS] Starting transcoder for file283-b61fb4b180cd at 0s from 81.152.190.1 (encoder=remux, resolution=, deinterlacer=, bitrate=10000)
[h264 @ 0x7fd93c038a00] mmco: unref short failure
[mpegts @ 0x7fd93c008600] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x7fd93c008600] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 0x7fd93c008600] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fd93c008600] Could not find codec parameters for stream 2 (Audio: aac_latm ([17][0][0][0] / 0x0011), 0 channels, fltp): unspecified sample rate
[aac @ 0x7fd93d815400] 2 frames left in the queue on closing
