When I try to access my web browser UI as I usually do it just refuses to load. The only thing I can think of that changed is I install the Xfinity PODS to extend my wireless service at my home. Would something in my router settings have changed to block the port or something? Any advice?
Sounds like you might have two networks now, and the wired and Wi-Fi devices are on different subnets.
What is the IP of the dvr and the IP of the device where you're connecting from?
that helped me figure it out, My IP address was changed so I just had to change my bookmark for the WEB UI..thanks
You can setup static dhcp reservations on your router
