Web Interface will not Transcode
When I use the WEB UI, I cannot view either recordings or live programs. I can view the recordings using VLC. The screen shows Transcoding starting then immediately stops. From the log:
017/05/11 09:15:04 [HLS] Starting transcoder for file-530 at 5m0s (encoder=h264_videotoolbox, resolution=720, deinterlacer=linear, bitrate=4000)
[mpegts @ 0x7fe25c008000] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fe25c008000] Dropped corrupted packet (stream = 2)
Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Error initializing output stream 0:0 –
2017/05/11 09:15:08 [HLS] Stopping transcoder for file-530 after seek to 5m0s (out=0s, finished=true)
2017/05/11 09:15:08 [HLS] Starting transcoder for file-530 at 5m0s (encoder=h264_videotoolbox, resolution=720, deinterlacer=linear, bitrate=4000)
[mpegts @ 0x7fa80b008600] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fa80b008600] Dropped corrupted packet (stream = 2)
2017/05/11 09:15:12 [HLS] Stopping transcoder for file-530 after seek to 5m0s (out=0s, finished=true)
2017/05/11 09:15:12 [HLS] Starting transcoder for file-530 at 5m0s (encoder=h264_videotoolbox, resolution=720, deinterlacer=linear, bitrate=4000)
[mpegts @ 0x7fcfb5008000] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fcfb5008000] Dropped corrupted packet (stream = 2)
2017/05/11 09:15:18 [HLS] Stopping transcoder for file-530 after seek to 5m0s (out=0s, finished=true)
Thanks,
Mike
Sounds like a permissions issue. I recommend that you delete the Streaming directory in your recordings folder and try again. Also make sure the recordings folder itself is writable by your user.
