Problem seen on Version 2018.11.06.2356 (and all 3 later pre-release versions)
It's been a many days since I have used the web player on another machine in the home to view a recording.
Using Chrome, everything is hardwired to a gigabit switch
Recording starts to play, and then playback ends after I hit my buffer (5min).
Here is the log from a restart. once the message [h264_mf @ 0000000001493dc0] stream format change
the web player stops and goes back to the title screen.
I've rolled back one by one to the 11/6 version and still have the error. Playback is Hardware, Blend, 1080p 10mbs
2018/11/16 15:21:20 [SYS] Starting Channels DVR v2018.11.06.2356 (windows-x86_64 pid:2624) in C:\ProgramData\ChannelsDVR\data
2018/11/16 15:21:20 [SYS] Running as a Windows system service.
2018/11/16 15:21:22 [HDR] Found 2 devices
2018/11/16 15:21:23 [SYS] Started HTTP Server
2018/11/16 15:21:24 [DVR] Recording engine started in X:\DVR
2018/11/16 15:21:24 [DVR] Waiting 38m35.9332768s until next job 1542405600-1 Judge Judy
2018/11/16 15:21:24 [SYS] Bonjour service running for dvr-mediapc.local. [192.168.10.45]
2018/11/16 15:21:24 [NAT] Successfully mapped port 8089 using natpmp
2018/11/16 15:21:24 [SYS] Created database snapshot: backup-20181116.152124
2018/11/16 15:21:24 [SYS] Removing old backup backup-20181028.163425
2018/11/16 15:21:34 [IDX] Pruned 0 expired airings from HDHR-PREMIUM in 74.9567ms.
2018/11/16 15:21:34 [IDX] Pruned 0 expired airings from USA-OTA60014 in 45.9736ms.
2018/11/16 15:21:41 [HLS] Starting transcoder for file72-ip192.168.10.199 at 3m26s from 192.168.10.199 (encoder=h264_mf, resolution=1080, deinterlacer=blend, bitrate=10000)
[mpegts @ 000000000118c180] Dropped corrupted packet (stream = 2)
[mpegts @ 000000000118c180] Dropped corrupted packet (stream = 3)
Last message repeated 1 times
