DVR Server Version: 2019.01.22.2346
Server OS: MacOS 10.14.3
Noticed that the web player is skipping when streaming recorded content, but not streaming live content. I get a slew of the following errors and it does not matter what encoding resolution I set. The iOS player does not have the same problem on the same recorded content.
Also, the transcoding counter in the web player does not increment.
[mpegts @ 0x7fd92d800000] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fd92d800000] Dropped corrupted packet (stream = 2)
2019/01/23 16:36:40 [HLS] Stopping transcoder for file3396-ipfe804beaf0cc736e183%en1 after seek to 2m12s (out=0s, finished=false)
2019/01/23 16:36:40 [HLS] Starting transcoder for file3396-ipfe804beaf0cc736e183%en1 at 2m12s from fe80::4be:af0c:c736:e183%en1 (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=1000)
[mpegts @ 0x7fcafe001200] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fcafe001200] Dropped corrupted packet (stream = 2)
2019/01/23 16:36:40 [HLS] Stopping transcoder for file3396-ipfe804beaf0cc736e183%en1 after seek to 2m13s (out=0s, finished=false)
2019/01/23 16:36:40 [HLS] Starting transcoder for file3396-ipfe804beaf0cc736e183%en1 at 2m13s from fe80::4be:af0c:c736:e183%en1 (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=1000)
[mpegts @ 0x7fcba6808000] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fcba6808000] Dropped corrupted packet (stream = 2)
2019/01/23 16:36:41 [HLS] Stopping transcoder for file3396-ipfe804beaf0cc736e183%en1 after seek to 2m14s (out=0s, finished=false)
2019/01/23 16:36:41 [HLS] Starting transcoder for file3396-ipfe804beaf0cc736e183%en1 at 2m14s from fe80::4be:af0c:c736:e183%en1 (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=1000)
[mpegts @ 0x7fc2a0008000] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fc2a0008000] Dropped corrupted packet (stream = 2)
2019/01/23 16:36:42 [HLS] Stopping transcoder for file3396-ipfe804beaf0cc736e183%en1 after seek to 2m15s (out=0s, finished=false)
2019/01/23 16:36:42 [HLS] Starting transcoder for file3396-ipfe804beaf0cc736e183%en1 at 2m15s from fe80::4be:af0c:c736:e183%en1 (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=1000)
[mpegts @ 0x7fa38c000000] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fa38c000000] Dropped corrupted packet (stream = 2)
2019/01/23 16:36:42 [HLS] Stopping transcoder for file3396-ipfe804beaf0cc736e183%en1 after seek to 2m16s (out=0s, finished=false)
2019/01/23 16:36:42 [HLS] Starting transcoder for file3396-ipfe804beaf0cc736e183%en1 at 2m16s from fe80::4be:af0c:c736:e183%en1 (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=1000)
[mpegts @ 0x7fb094001200] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fb094001200] Dropped corrupted packet (stream = 2)
2019/01/23 16:36:43 [HLS] Stopping transcoder for file3396-ipfe804beaf0cc736e183%en1 after seek to 2m17s (out=0s, finished=false)
2019/01/23 16:36:43 [HLS] Starting transcoder for file3396-ipfe804beaf0cc736e183%en1 at 2m17s from fe80::4be:af0c:c736:e183%en1 (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=1000)
[mpegts @ 0x7fcda3008000] Dropped corrupted packet (stream = 1)
[mpegts @ 0x7fcda3008000] Dropped corrupted packet (stream = 2)
2019/01/23 16:36:43 [HLS] Stopping transcoder session file3396-ipfe804beaf0cc736e183%en1 @ 0s
