I'm trying to play recordings remotely using the web ui and I keep getting a message saying remux paused as below. Live TV works fine through the UI and I can play recordings remotely through my iPhone, it's just the web UI with the issue? Log also below
2019/07/18 10:17:04 [HLS] Starting transcoder for file10-7d893d5eb972 at 0s from 217.138.36.2 (encoder=remux, resolution=1080, deinterlacer=, bitrate=8000)
[h264 @ 0x7f882e01bc00] mmco: unref short failure
[mpegts @ 0x7f882e008000] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x7f882e008000] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0x7f882e008000] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 0x7f882e008000] start time for stream 6 is not set in estimate_timings_from_pts
[mpegts @ 0x7f882e008000] start time for stream 7 is not set in estimate_timings_from_pts
[mpegts @ 0x7f882e008000] Dropped corrupted packet (stream = 1)
[hls @ 0x7f882d809000] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[mpegts @ 0x7f882e00dc00] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2019/07/18 10:17:12 [HLS] Pausing transcoder (out: 5m51.006333s, view: 48s)...
2019/07/18 10:18:29 [HLS] Stopping transcoder session file10-7d893d5eb972 @ 5m51.006333s
2019/07/18 10:18:29 [HLS] Resuming transcoder (out: 5m51.006333s, view: 54s)...
2019/07/18 10:18:32 [HLS] Starting transcoder for file3-7d893d5eb972 at 0s from 217.138.36.2 (encoder=remux, resolution=1080, deinterlacer=, bitrate=8000)
[h264 @ 0x7fb48181bc00] mmco: unref short failure
Last message repeated 1 times
[mpegts @ 0x7fb481808000] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x7fb481808000] start time for stream 3 is not set in estimate_timings_from_pts
[hls @ 0x7fb481809200] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[mpegts @ 0x7fb481836a00] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2019/07/18 10:18:41 [HLS] Pausing transcoder (out: 5m47.854944s, view: 27s)...
2019/07/18 10:19:07 [HLS] Stopping transcoder session file3-7d893d5eb972 @ 5m47.854944s
2019/07/18 10:19:07 [HLS] Resuming transcoder (out: 5m47.854944s, view: 27s)...
2019/07/18 10:19:15 [TNR] Opened connection to 12503076 for ch15 Channel 4+1
2019/07/18 10:19:15 [HLS] Starting transcoder for channel 15 from 217.138.36.2 (encoder=h264_videotoolbox, resolution=1080, deinterlacer=blend, bitrate=8000)
[h264_videotoolbox @ 0x7fb844813e00] Color range not set for yuv420p. Using MPEG range.
2019/07/18 10:19:26 [HLS] Stopping transcoder session ch15-dANY-7d893d5eb972 @ 9.2s
2019/07/18 10:19:26 [TNR] Closed connection to 12503076 for ch15 Channel 4+1
