Weird Channel Availablity
Devs,
I have a weird issue with a channel from two different sources. I have a news outlet from Spectrum (6789) and the same outlet from Pluto (9076). Both channels show up in the guide and as automatic channels, but I'm unable to add 9076 to any Channel Collection...it doesn't appear as an option when adding channels. 6789 is available to be added to a collection.
Where do I start troubleshooting this ??
Thank you...
If you use the Pluto filter when listing channels, does it show?
Do you have it set as hidden in the Pluto lineup?
No...doesn't show when I filter listings and isn't a hidden channel. I can go to the global guide and its available and can be watched.
