Latest ATV4k model, hardwired.
Just submitted diagnostics. Doesn’t seem to be specific to source or source type.
Submitted another one while on live TV against a cable source, which is the polar opposite of my original Diags post (1st was a recorded ATSC3 session)
I'm openly wondering if my M1 mac mini (which was repaired by apple after a lightning strike) may be at fault here.
One thing that's been annoying me - upgrades seem to be interacting with the NIC/mac badly, as in it makes the mac inaccessible for a time, even from VNC. The log shows this (note the bolded time jump - this should be nearly instantaneous):
I submitted a0a40e98-26ae-42c9-9715-e9fbaca6ac24 on off chance it sheds some light.
2023/06/28 06:56:37.452604 [SYS] Goodbye.
2023/06/28 06:56:38.422945 [SYS] Starting Channels DVR v2023.06.28.0049 (darwin-arm64 pid:32558) in /Users/hancox/Library/Application Support/ChannelsDVR/data
2023/06/28 06:56:38.472035 [SYS] Started HTTP Server on 8089
2023/06/28 06:56:39.890648 [HDR] Found 5 devices
2023/06/28 07:11:50.513902 [ERR] Failed to request m3u for FrndlyTV2: Get "http://localhost:8183/playlist.m3u8?gracenote=exclude": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
2023/06/28 07:11:55.705516 [M3U] Refreshed lineup for PBSStreamingFeed with 3 channels
2023/06/28 07:11:55.889933 [M3U] Refreshed lineup for SamsungTVPlus with 255 channels
2023/06/28 07:11:55.900817 [M3U] Refreshed lineup for ESPNPlus with 150 channels
2023/06/28 07:11:58.517198 [M3U] Refreshed lineup for FrndlyTV1 with 40 channels
2023/06/28 07:11:59.153445 [DVR] Waiting 10h17m50.846563s until next job 1687987790-3 Pardon the Interruption
2023/06/28 07:11:59.233783 [DVR] Recording engine started in /Volumes/DVR_SSD
2023/06/28 07:11:59.235885 [SYS] Removing old update 2023.06.16.2040
2023/06/28 07:11:59.248081 [NAT] Successfully mapped port 8089 using natpmp
2023/06/28 07:11:59.442689 [SYS] Created database snapshot: backup-20230628.111159
2023/06/28 07:11:59.442799 [SYS] Removing old backup backup-20230614.114237
2023/06/28 07:12:00.071907 [SYS] Bonjour service registered with Roberts-mini
...and just so you don't think I'm crazy, my router concurs:
Jun 28 06:56:45 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Jun 28 06:56:47 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link Up at 100 mbps full duplex
Jun 28 07:11:42 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Jun 28 07:11:48 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link Up at 1000 mbps full duplex
Any chance this is mine?
Either way - I got a great deal on an M2 mini/M1 trade-in, so I'm covering that base now
No, I don't think this was your issue. It looks like your was due to a problem in handling of corrupted ATSC3 signals.
Thanks, but only the 1st case was ATSC3. Live cable watching was 2nd case
