What does "Shows" mean in Library Database?
Yesterday I setup a gethomepage.dev site, and installed the ChannelsDVR widget. One thing I am curious about it what the Shows section refers to? I see it matches up with the Library Database in General settings. It isn't a huge deal, but for the life of me I can't figure out what the 59 shows is referring to. I have nothing in my Library outside of the 29 recordings for the 16 passes.
It's the number of tv shows ever recorded
It's the number of shows and video groups that you recorded or imported since day 1.
You can view the list at http://<dvr_ip:port>/dvr/groups?all=true
Channels doesn’t show empty shows. But it does retain them in case of any edits you have made.
This is sort of a long standing bug in that it reports the total count, even if they’re not visible.
Thanks guys. I just went ahead and removed shows from my homepage setup.
