What happens if I don't specify a channel?
I’m new to Channels DVR and just setup a few passes. I looked up the show using, “Search” and set it up to record only new episodes, I didn’t specify a channel. Will I get multiple recordings this way? Just wondering if I should go back and actually put a channel number in there?
No need to pick a channel if you don’t want. The DVR will automatically pick the best channel, based on which ones are HD and if any are in your favorites list.
That’s fantastic, thank you.
