What is ‘On Later’ and where did recordings go? v3.1.10
In today’s release v3.1.10 I’ve lost the Recordings tab that’s
I’ve got the beta that shows my recordings so there is no panic, everything is there. I just figured it’s a glitch to report.
Menu says
On Now Guide On Later DVR Search Settings
And no recordings show under On Now
Same here I lost the recordings tab. How do access my recordings? It was there yesterday
It’s an old never used tab that got exposed by a bug :fearful:
You can get recordings back by force quitting the app and reopening it. So sorry about this eveyone. We have a fix submitted waiting for review right now.
Quit the app by clicking the TV/Home button twice and swipe up. Relaunch and it should be fixed.
Did not work for me. When I force quit the app and go back in no dvd tabs show. I have to exit the app and go back in for the tabs to show up again, but still no record recordings tab
update > i just went to the web interface and disabled bonjour then turned it back on. And then when I force quit the app and went back in the dev tabs were there with recordings tab
Neither worked for me. No biggie the beta works fine until the fix comes through
UPDATE:
I upgraded to v2018.03.16.0555 of the server and the
RECORDINGS returned
Everything should be back to normal now.
