How can I find out what local channels I will receive and if there are any blackouts? I’m in Tampa Bay.
You can use tvfool.com to search your location and see which TV towers are near you and which channels you should expect to be able to pick up with an OTA antenna.
http://www.tvfool.com/index.php?option=com_wrapper&Itemid=90
Thanks for the reply;
I’m asking about the Channels app, not an outdoor antenna.
I just bought a winegard 60 mile antenna and was going to have it installed this weekend but then I saw the “Channels” app on my new AppleTV gen4. I’d like to “amazon return” the antenna and just buy the Channels app for $24.99. It says on the channels app info that you can get local channels, I need to know if I’m going to get the three ABC, CBS & NBC. How can I find out what local channels I will get on the “Channels” app before I return my antenna that I bought?
I appreciate the reply-thanks-
Jeff
Channels does not provide TV by itself. It utilizes a network enabled TV tuner called an HDHomeRun. The HDHomeRun Connect model uses an OTA antenna to receive TV. You can also use the Prime model with a cable card to get cable channels from your cable subscription.
You can learn more on our site: https://getchannels.com or in our FAQ: https://getchannels.com/faq/
