if one were to use the .edl files created by channels to remove commercials and re-export the file (using, say, LosslessCut), what actions are necessary afterwards?
i assume at a minimum one should remove the .edl sidecar file, but it seems that channels is keeping the commercial skip info in its database as well (so maybe it would just reappear.) also i assume channels is tracking the file duration. does "regenerate video index" take care of this? or is there some other housekeeping task to run?
IOW how to make sure channels knows the new file duration is shorter and any comskip info should be discarded?
thanks, rob
