any updates on this problem
This is a problem on Fubo's side since you can't even login and watch with Fubo on sites like TBS.com or HGTV.com
ok thank you
Yes its a problem on FuboTV’s end. Im 3 weeks in with this issue and going back and forth with FuboTV support. They told me to contact the networks I have issues logging in with TVE (which is all of them) I went ahead and contacted NFL Network And NBC and they noted the issues are coming from FuboTV end.
Now whats strange is i have friends who use FuboTV (but not Channels DVR) and they have no problems connecting to Networks apps or sites. My Crazy head tends to think FuboTV is blocking me from being able to use TVE and not telling me straight up. Could me using Channels DVR with TVE cause FuboTV to Block me? I think this is something thing we need to look into.
Can you login separately with a web browser to the streaming websites using your Fubo credentials to stream from them? That's what Channels DVR does.
If not, it's simply a Fubo TVE auth issue.
no login for foxsports nbc hgtv etc website or apps
but have friend can do all but dont use tve
I was having an issue similar to this (I don't recall the exact error) a few weeks back. I was also losing more channels as time went by.
I removed and re-added the source and all has been fine since.
Not conclusive, but I believe my problem to have been with removing a couple other tve sources when I was switching to fubotv….
Well, reading this post must have jinxed me, the issue returned. I had to delete and recreate the source. Now I have 4 less channels as well.
Is this being looked at by anyone?
Well got email back
They said would fix
Now can login to fox sports and hand full others
Same error on channels
I had a trial of Fubo....never got it to work with CHannels.
Either got chrome_timeout error or this data not found.
ALso, did not know if i should enter full email address or just the first part for the "username". Gave up. dont like thier app anyways.
update up and working again on fubotv
