My PC auto logins but the DVR wont start, I end up having to delete folder in program data and reinstalling. What service/file should be starting upon reboot? Appreciate any help as it works great other than this.
There’s no reason to reinstall… you can type “Channels DVR” in the start menu to boot it up.
It is supposed to start at login however. Can you check the Task Manager and see if it is listed under Startup Items?
It is listed under startup items in control panel (and enabled), only way to check is to restart my PC again. If I type channels DVR in search box, it launches a browser connecting to service but I am afraid if I restart it again, the service will not be running for web page to connect to anything.
If it’s running already it launches a browser. If it’s not running, it starts it up.
Not sure why it’s not starting automatically when it’s listed on startup items…
Next time you reboot, can you check the log file under the ProgramData dir to see if it has any errors listed?
apparently tried to automatically update and it didn’t come back up. Rebooted PC and still not go. below is log file, thanks for the help!
[DVR] queued recording job 1491274800-18
2017/03/21 09:42:57 [DVR] queued recording job 1491276600-18
2017/03/21 14:45:52 [SYS] Downloading new version v2017.03.21.0415
2017/03/21 14:45:58 [SYS] Update downloaded and verified successfully.
2017/03/21 14:45:58 [SYS] Shutting down for upgrade from v2017.03.13.2338 to v2017.03.21.0415
2017/03/21 14:45:58 [DVR] Recording engine stopped.
2017/03/21 14:46:01 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 14:46:05 [HDR] Found 1 devices
2017/03/21 14:46:06 [SYS] Started HTTP Server
2017/03/21 14:46:06 Corruption: 79 missing files; e.g.: USA-OTA06460.airings\store/002132.ldb
2017/03/21 20:14:22 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 20:14:24 [HDR] Found 1 devices
2017/03/21 20:14:25 [SYS] Started HTTP Server
2017/03/21 20:14:25 Corruption: 79 missing files; e.g.: USA-OTA06460.airings\store/002132.ldb
2017/03/21 20:15:42 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 20:15:44 [HDR] Found 1 devices
2017/03/21 20:15:45 [SYS] Started HTTP Server
2017/03/21 20:15:45 Corruption: 79 missing files; e.g.: USA-OTA06460.airings\store/002132.ldb
2017/03/21 20:20:15 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 20:20:27 [HDR] Found 1 devices
2017/03/21 20:20:31 [SYS] Started HTTP Server
2017/03/21 20:20:34 Corruption: 79 missing files; e.g.: USA-OTA06460.airings\store/002132.ldb
2017/03/21 20:21:25 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 20:21:28 [HDR] Found 1 devices
2017/03/21 20:21:29 [SYS] Started HTTP Server
2017/03/21 20:21:29 Corruption: 79 missing files; e.g.: USA-OTA06460.airings\store/002132.ldb
2017/03/21 20:22:29 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 20:22:31 [HDR] Found 1 devices
2017/03/21 20:22:31 [SYS] Started HTTP Server
2017/03/21 20:22:32 Corruption: 79 missing files; e.g.: USA-OTA06460.airings\store/002132.ldb
Ick, your guide database has become corrupted.
Please delete c:\programdata\channelsDVR\data\USA-OTA06460.airings and then start the DVR engine again.
deleted entire folder, app wont start…rebooted and here is the end of the log file currently:
Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-21 9:30AM
2017/03/21 09:40:13 [DVR] indexed 222 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:40:14 [DVR] indexed 11 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:40:15 [DVR] pruned 10 replaced airings in 1s.
2017/03/21 09:40:16 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-21 3:30PM
2017/03/21 09:40:19 [DVR] indexed 251 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:40:20 [DVR] indexed 6 movies (3 channels) [0s fetch, 0s index]
2017/03/21 09:40:21 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-21 9:30PM
2017/03/21 09:40:24 [DVR] indexed 231 airings (28 channels) [1s fetch, 1s index]
2017/03/21 09:40:25 [DVR] indexed 8 movies (3 channels) [0s fetch, 0s index]
2017/03/21 09:40:25 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-22 3:30AM
2017/03/21 09:40:29 [DVR] indexed 228 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:40:29 [DVR] indexed 10 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:40:30 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-22 9:30AM
2017/03/21 09:40:32 [DVR] indexed 226 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:40:33 [DVR] indexed 10 movies (5 channels) [0s fetch, 0s index]
2017/03/21 09:40:34 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-22 3:30PM
2017/03/21 09:40:37 [DVR] indexed 254 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:40:38 [DVR] indexed 5 movies (2 channels) [0s fetch, 0s index]
2017/03/21 09:40:39 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-22 9:30PM
2017/03/21 09:40:42 [DVR] indexed 238 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:40:43 [DVR] indexed 5 movies (2 channels) [0s fetch, 0s index]
2017/03/21 09:40:44 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-23 3:30AM
2017/03/21 09:40:46 [DVR] indexed 228 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:40:47 [DVR] indexed 10 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:40:48 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-23 9:30AM
2017/03/21 09:40:51 [DVR] indexed 228 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:40:52 [DVR] indexed 8 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:40:53 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-23 3:30PM
2017/03/21 09:40:56 [DVR] indexed 249 airings (28 channels) [1s fetch, 1s index]
2017/03/21 09:40:57 [DVR] indexed 3 movies (1 channels) [0s fetch, 0s index]
2017/03/21 09:40:57 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-23 9:30PM
2017/03/21 09:41:00 [DVR] indexed 228 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:41:01 [DVR] indexed 6 movies (2 channels) [0s fetch, 0s index]
2017/03/21 09:41:02 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-24 3:30AM
2017/03/21 09:41:05 [DVR] indexed 233 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:41:06 [DVR] indexed 8 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:41:06 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-24 9:30AM
2017/03/21 09:41:09 [DVR] indexed 225 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:41:10 [DVR] indexed 11 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:41:10 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-24 3:30PM
2017/03/21 09:41:14 [DVR] indexed 247 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:41:14 [DVR] indexed 5 movies (2 channels) [0s fetch, 0s index]
2017/03/21 09:41:15 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-24 9:30PM
2017/03/21 09:41:19 [DVR] indexed 229 airings (28 channels) [1s fetch, 1s index]
2017/03/21 09:41:19 [DVR] indexed 7 movies (2 channels) [0s fetch, 0s index]
2017/03/21 09:41:20 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-25 3:30AM
2017/03/21 09:41:23 [DVR] indexed 250 airings (28 channels) [1s fetch, 1s index]
2017/03/21 09:41:24 [DVR] indexed 10 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:41:24 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-25 9:30AM
2017/03/21 09:41:28 [DVR] indexed 256 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:41:29 [DVR] indexed 9 movies (6 channels) [0s fetch, 0s index]
2017/03/21 09:41:30 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-25 3:30PM
2017/03/21 09:41:34 [DVR] indexed 211 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:41:34 [DVR] indexed 14 movies (9 channels) [0s fetch, 0s index]
2017/03/21 09:41:35 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-25 9:30PM
2017/03/21 09:41:38 [DVR] indexed 209 airings (28 channels) [1s fetch, 1s index]
2017/03/21 09:41:39 [DVR] indexed 14 movies (8 channels) [0s fetch, 0s index]
2017/03/21 09:41:40 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-26 3:30AM
2017/03/21 09:41:43 [DVR] indexed 252 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:41:44 [DVR] indexed 13 movies (6 channels) [0s fetch, 0s index]
2017/03/21 09:41:45 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-26 9:30AM
2017/03/21 09:41:47 [DVR] indexed 207 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:41:48 [DVR] indexed 16 movies (7 channels) [0s fetch, 0s index]
2017/03/21 09:41:49 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-26 3:30PM
2017/03/21 09:41:52 [DVR] indexed 183 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:41:52 [DVR] indexed 14 movies (7 channels) [0s fetch, 0s index]
2017/03/21 09:41:53 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-26 9:30PM
2017/03/21 09:41:56 [DVR] indexed 212 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:41:56 [DVR] indexed 10 movies (6 channels) [0s fetch, 0s index]
2017/03/21 09:41:57 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-27 3:30AM
2017/03/21 09:42:00 [DVR] indexed 227 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:42:01 [DVR] indexed 9 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:42:02 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-27 9:30AM
2017/03/21 09:42:05 [DVR] indexed 226 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:42:06 [DVR] indexed 11 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:42:06 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-27 3:30PM
2017/03/21 09:42:10 [DVR] indexed 251 airings (28 channels) [2s fetch, 1s index]
2017/03/21 09:42:10 [DVR] indexed 5 movies (2 channels) [0s fetch, 0s index]
2017/03/21 09:42:11 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-27 9:30PM
2017/03/21 09:42:14 [DVR] indexed 235 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:42:15 [DVR] indexed 8 movies (3 channels) [0s fetch, 0s index]
2017/03/21 09:42:16 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-28 3:30AM
2017/03/21 09:42:18 [DVR] indexed 229 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:42:19 [DVR] indexed 11 movies (5 channels) [0s fetch, 0s index]
2017/03/21 09:42:20 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-03-28 9:30AM
2017/03/21 09:42:23 [DVR] indexed 227 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:42:24 [DVR] indexed 11 movies (5 channels) [0s fetch, 0s index]
2017/03/21 09:42:34 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-04-03 9:30AM
2017/03/21 09:42:37 [DVR] indexed 231 airings (28 channels) [1s fetch, 1s index]
2017/03/21 09:42:38 [DVR] indexed 7 movies (4 channels) [0s fetch, 0s index]
2017/03/21 09:42:39 [DVR] pruned 13 replaced airings in 0s.
2017/03/21 09:42:39 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-04-03 3:30PM
2017/03/21 09:42:41 [DVR] indexed 247 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:42:42 [DVR] indexed 5 movies (2 channels) [0s fetch, 0s index]
2017/03/21 09:42:42 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-04-03 9:30PM
2017/03/21 09:42:45 [DVR] indexed 240 airings (28 channels) [2s fetch, 0s index]
2017/03/21 09:42:46 [DVR] indexed 4 movies (1 channels) [0s fetch, 0s index]
2017/03/21 09:42:46 [DVR] Fetching guide data for 28 stations in USA-OTA06460 @ 2017-04-04 3:30AM
2017/03/21 09:42:49 [DVR] indexed 241 airings (28 channels) [1s fetch, 0s index]
2017/03/21 09:42:49 [DVR] indexed 6 movies (3 channels) [0s fetch, 0s index]
2017/03/21 09:42:50 [IDX] Pruned 0 expired groups from USA-OTA06460 in 1.0012ms.
2017/03/21 09:42:56 [IDX] Pruned 871 expired airings from USA-OTA06460 in 6.7423854s.
2017/03/21 09:42:56 [DVR] Rule 'Seinfeld' found 2 new airings
2017/03/21 09:42:57 [DVR] queued recording job 1491274800-18
2017/03/21 21:42:59 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:43:01 [HDR] Found 1 devices
2017/03/21 21:43:02 [SYS] Started HTTP Server
2017/03/21 21:43:03 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
2017/03/21 21:43:04 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:43:05 [HDR] Found 1 devices
2017/03/21 21:43:06 [SYS] Started HTTP Server
2017/03/21 21:43:06 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
2017/03/21 21:43:15 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:43:17 [HDR] Found 1 devices
2017/03/21 21:43:18 [SYS] Started HTTP Server
2017/03/21 21:43:18 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
2017/03/21 21:43:26 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:43:28 [HDR] Found 1 devices
2017/03/21 21:43:29 [SYS] Started HTTP Server
2017/03/21 21:43:29 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
2017/03/21 21:43:37 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:43:39 [HDR] Found 1 devices
2017/03/21 21:43:39 [SYS] Started HTTP Server
2017/03/21 21:43:40 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
2017/03/21 21:45:36 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:45:38 [HDR] Found 1 devices
2017/03/21 21:45:39 [SYS] Started HTTP Server
2017/03/21 21:45:39 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
2017/03/21 21:50:00 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:50:13 [HDR] Found 1 devices
2017/03/21 21:50:17 [SYS] Started HTTP Server
2017/03/21 21:50:22 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
2017/03/21 21:51:04 [SYS] Starting Channels DVR v2017.03.21.0415 (windows-x86_64) in C:\ProgramData\ChannelsDVR\data
2017/03/21 21:51:08 [HDR] Found 1 devices
2017/03/21 21:51:09 [SYS] Started HTTP Server
2017/03/21 21:51:10 Corruption: 4 missing files; e.g.: USA-OTA06460.groups\store/000157.ldb
You need to delete USA-OTA06460.groups as well.
