There's an option to add TV shows to "Favorites", but where is "Favorites"?
Help file just says "This will place them in their own sections in Movies and TV Shows", but I don't see them there.
I know this is an Android TV topic, but in tvOS the "Favorites" show up in the top row of the TV Shows section above "Recently Watched Shows".
For Movies? I actually have no idea where they go. There definitely used to be a first row like the TV Shows but it seems like it has disappeared.
I tested favoriting a couple of movies and then went into All Movies and under Filter there was an option for "Favorited" where they show up.
I imagine there's an option to create a personal section to show those specifically somehow.
Just to add to this - I would expect Favorite movies to appear on the top of the Movies menu item, but it doesn't seem to work (at least on my iPad). They do however, show on the top of the listing in the web interface though.
Favorited Movies and TV Shows show up in their own row when you have Enhanced Library Browsing enabled, which gives you a richer browsing experience.
Without that turned on, Movies and TV shows are just displayed as a flat list with the ability to adjust their sort or filter them. It's with these filter options you can see your favorited movies and TV shows.
This is a bug, which just got fixed today actually! Look for it in the next TestFlight beta.
Hmmmm...just downloaded the latest update from Testflight and it's still not showing the Favorites row? (This is on IOS).
Confirmed that I have Enhanced Library enabled as well.
OK, the fix is in this build.
Confirmed it’s working now.
