Where do downloads go?
Channels iPad app (Version 6.1.2 (10.11.1326)) running on a Macbook Air M1 Sequoia 15.1.1.
So I accidentally asked it to download a recording but I can't find where it went. Downloaded another one, confirming Channels wrote a bunch to disk, so I'm pretty sure it's being written. But I can't find them. Looked in all the likely locations, and even did a full volume scan for Channels.
Can anyone tell me where they went so I can delete them?
If it is like iOS you just delete them from inside the app. Downloads is a sidebar option, if it isn’t showing there check settings or just disconnect from LAN and WAN networks and launch the app. When it can’t find the server all your downloads will show up. Delete them from there.
Like @Rice said, that's just the iPad app, so it acts like it and has no access to real files. The only place the downloads are usable are inside the app.
