I simply use the Channels app without DVR on Firestick. I hate the newer versions since the tv guide is always stuck and needs to have me clear cache up to 5 times per day. Never had this issue on earlier versions. Where do I find earlier versions to sideload so it will never update again? Thank you
Channels does not support turning off updates. To much work for support to support older versions.
He’s asking for an older APK of the Android client, not previous versions of the CDVR server.
Check adbmirror for stuff like that.
