Greetings,
I have my Channels DVR server on my Windows 11 Pro PC that never sleeps. I have many show with series recorded, when I go to the Channels DVR app on my ATV 4K and open the app and go to "recordings" I donot see my library, I see recorded today and all the recorded precious days?
Where is my library?
Have you looked at TV Shows?
Have you looked at Movies?
but I donot see that on the app on my ATV 4K
I use the Android version yet id expect them to be similar. You can configure the interface in the apps settings. Both should be on by default.
OK,
Thanks, I will look a little deeper. Strange that the "library" isn't very visable as soon as you click "recordings"?
Try the Home tab
ok, I will try that also, thanks everyone for your help.
I Use ONN android boxes on Win 11.
Here is how it works for me, as I understand it.
First: To get shows to show up in TV Show you should have a Pass set up.
It will also put a one time recording in TV Show if it is from TVE.
How does it know it's a TV show and not a Movie? The stream has "metadata" with that tag.
On the Client box select Settings, General, Manage Navigation, THEN set TV Shows, Movies to ON.
Now on your Left most column where you Select Guide, Recordings, etc you will See TV Shows, Movies.
When you click those it will show all recordings in those categories, you can order them,
TV Shows are Grouped by Show name, there could be many episodes,
when you Click a TV Show you can pick the one you want and will see all recordings for that Show
to Watch or Delete, and you can Delete the whole collection of that TV Show.
thanks, but I found my recordings simply going to home. Thanks for the reply
I don't think I've ever clicked on the Home tab
Good to know.
