Hi -
Tried to locate but can’t find where to download. Thanks in advance!
Hi -
The SPK is the same but you can upgrade after installing it
Sorry, not sure I understand...
The installer spk is updated very infrequently as is still at v1.0.5 here https://getchannels.com/dvr-server/#synology
Once you install it you can update the server code to the latest pre-release version.
Their support docs show the old way https://getchannels.com/docs/getting-started/faqs/channels-plus/#how-do-i-update-to-the-pre-release-version-of-channels-dvr-server
But once you're on a newer version you can use the dropdown
Thanks for that, I’ll give it a try!
Thanks for the help, that worked and resolved the issue I was having!
