While watching live TV will freeze up and say connnection lost
When watching channels on apple 4k, image will freez then will say connection lost.
When I back out of that message, I do get back to the list of live channels.
Need more information. What is the source of the live Tv? How is the Apple TV connected to the network?
We are using outdoor antenna. Using Hd homerun Extend to connect to router.
How is the Apple TV connected to the network? First thing to check is network connectivity problems. Any errors in the DVR error log at the time of the issue?
The internet is up, I do a speed test on my phone using WIFI. I did up load diagnostic logs.
Still having connection lost errors when watching Channels live with Over The Air antenna. We changed from 2.4 g to 5g and that helps a lot regarding live programs stuttering and freezing up. But still have connection lost errors.
I can't see the log because the screen reader I use will not verbalize them.
Is it possible to even temporarily hard wire the Apple TV to see if the issue stops? It’s impossible to tell without seeing the logs but this is likely wifi instability. Also.. do you have tuner sharing enabled on your client?
how can I get a log file to you? To have you look at it?
From the web ui you can go to the support area and see the logs there. You can just copy and paste the text from the timeframe you have the issue into the thread here and we may be able to help. There is also an option to submit diagnostics in that support area that will send lots of information to the Devs and perhaps allow them to chip in as well.
Shared tuner is turned off.
can't figure out how to get at the log files on the channels page. Many of the elliments are not tagged correctly to work with voiceover. I did submit logs from the channels app on my apple TV.
From the DVR web UI, navigate to Support > Logs
Submitting logs from Apple TV will also cause the DVR to submit logs, I believe. So hopefully the Devs can see something in them to help.
the navigation menue needs to be fixed so it will work with voiceover. below are log file during a connection lost event. I will also upload the log file from the channels app
(64 channels) [0s fetch, 0s index]
2021/10/13 09:05:13.612994 [DVR] indexed 19 movies (6 channels) [0s fetch, 0s index]
2021/10/13 09:05:13.621995 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-16 3:00AM
2021/10/13 09:05:14.505035 [DVR] indexed 578 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:14.764478 [DVR] indexed 3 movies (1 channels) [0s fetch, 0s index]
2021/10/13 09:05:14.771478 [DVR] pruned 1 replaced airings in 0s.
2021/10/13 09:05:14.774476 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-16 9:00AM
2021/10/13 09:05:15.571396 [DVR] indexed 450 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:15.985811 [DVR] indexed 24 movies (10 channels) [0s fetch, 0s index]
2021/10/13 09:05:15.990999 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-16 3:00PM
2021/10/13 09:05:17.044796 [DVR] indexed 392 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:17.537961 [DVR] indexed 28 movies (10 channels) [0s fetch, 0s index]
2021/10/13 09:05:17.542081 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-16 9:00PM
2021/10/13 09:05:18.284774 [DVR] indexed 432 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:18.662526 [DVR] indexed 25 movies (9 channels) [0s fetch, 0s index]
2021/10/13 09:05:18.670525 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-17 3:00AM
2021/10/13 09:05:22.943687 [DVR] indexed 564 airings (64 channels) [3s fetch, 0s index]
2021/10/13 09:05:23.366508 [DVR] indexed 6 movies (4 channels) [0s fetch, 0s index]
2021/10/13 09:05:23.372651 [DVR] pruned 1 replaced airings in 0s.
2021/10/13 09:05:23.377001 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-17 9:00AM
2021/10/13 09:05:24.224813 [DVR] indexed 458 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:24.522549 [DVR] indexed 17 movies (8 channels) [0s fetch, 0s index]
2021/10/13 09:05:24.526547 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-17 3:00PM
2021/10/13 09:05:25.451034 [DVR] indexed 452 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:25.827030 [DVR] indexed 22 movies (9 channels) [0s fetch, 0s index]
2021/10/13 09:05:25.833288 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-17 9:00PM
2021/10/13 09:05:26.665109 [DVR] indexed 467 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:27.004624 [DVR] indexed 19 movies (8 channels) [0s fetch, 0s index]
2021/10/13 09:05:27.012623 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-18 3:00AM
2021/10/13 09:05:27.857273 [DVR] indexed 541 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:28.237179 [DVR] indexed 11 movies (6 channels) [0s fetch, 0s index]
2021/10/13 09:05:28.241829 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-18 9:00AM
2021/10/13 09:05:29.149596 [DVR] indexed 482 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:29.488147 [DVR] indexed 15 movies (6 channels) [0s fetch, 0s index]
2021/10/13 09:05:29.497202 [DVR] Fetching guide data for 64 stations in USA-OTA55427 @ 2021-10-18 3:00PM
2021/10/13 09:05:30.370124 [DVR] indexed 487 airings (64 channels) [0s fetch, 0s index]
2021/10/13 09:05:30.705660 [DVR] indexed 16 movies (7 channels) [0s fetch, 0s index]
2021/10/13 09:05:30.713547 [DVR] Fetching guide data for 64 stations in USA-OT
Hmm. I see you mentioned you aren’t using tuner sharing, but we were so focused on getting the logs I think we missed that point. If you’re not using tuner sharing that means your client is connecting directly to the HDHomeRun when you’re watching live TV, and the DVR server is not involved. So, we don’t have any information about what is going wrong in the DVR logs unfortunately. The most likely culprit is still network connectivity, especially since you are on wifi. Have you tried investigating your wifi network at all to make sure you are using the least busy channel, etc.?
It might be worth a try to turn tuner sharing on and see if the behavior changes any. Even if it continues to happen at least the logs might have some data that could give us a direction to go in.
ok, turned on tuner sharing. audio/video really skips a lot. see log below. also sent by the app.
2021/10/20 19:44:09.456887 [TRS] Network Flow Control: OK
2021/10/20 19:44:09.967831 [TRS] Power Management: OK
2021/10/20 19:44:20.465523 New diagnostic log submitted under cc5fd8bb-d866-4242-aeef-ed8ae47a53a9
2021/10/21 00:30:00.013300 [DVR] Starting job 1634794200-110 Get Smart on ch=[9.6]
2021/10/21 00:30:00.013812 [DVR] Waiting 7h59m59.9861873s until next job 1634823000-101 Garden Smart
2021/10/21 00:30:00.013812 [DBG] Scheduling wake timer for scheduled recording in 7h58m29.9861873s
2021/10/21 00:30:00.687373 [TNR] Opened connection to 105836BC/0 for ch9.6 Decades
2021/10/21 00:30:00.688431 [DVR] Recording for job 1634794200-110 from 105836BC ch9.6 into "TV\Get Smart\Get Smart S05E17 1970-01-23 Rebecca of FunnyFolk Farm 2021-10-21-0030.mpg" for 29m59.9861873s
2021/10/21 00:30:00.734015 [IDX] Generating video index for job 1634794200-110
2021/10/21 01:00:00.024501 [SNR] Statistics for "TV\Get Smart\Get Smart S05E17 1970-01-23 Rebecca of FunnyFolk Farm 2021-10-21-0030.mpg": ss=67%,66%-69% snq=99%,93%-100% seq=99%,0%-100% bps=2389230,0-4832352 pps=211,0-415
2021/10/21 01:00:00.040651 [TNR] Closed connection to 105836BC/0 for ch9.6 Decades
2021/10/21 01:00:00.154375 [DVR] Finished job 1634794200-110 Get Smart
2021/10/21 01:00:00.175333 [DVR] Processing file-4189: TV\Get Smart\Get Smart S05E17 1970-01-23 Rebecca of FunnyFolk Farm 2021-10-21-0030.mpg
2021/10/21 01:00:00.176411 [DVR] Waiting 7h29m59.8235889s until next job 1634823000-101 Garden Smart
2021/10/21 01:00:00.176411 [DBG] Scheduling wake timer for scheduled recording in 7h28m29.8235889s
2021/10/21 01:00:00.649693 [DVR] Running commercial detection on file 4189 (TV\Get Smart\Get Smart S05E17 1970-01-23 Rebecca of FunnyFolk Farm 2021-10-21-0030.mpg)
2021/10/21 01:00:39.590674 [DVR] Commercial detection for Get Smart S05E17 1970-01-23 Rebecca of FunnyFolk Farm 2021-10-21-0030.mpg finished with 6 markers in 38.9436379s.
2021/10/21 08:30:00.006132 [DVR] Starting job 1634823000-101 Garden Smart on ch=[2.3]
2021/10/21 08:30:00.006132 [DVR] Waiting 6h59m29.9938675s until next job 1634848170-108 Whew!
2021/10/21 08:30:00.006132 [DBG] Scheduling wake timer for scheduled recording in 6h57m59.9938675s
2021/10/21 08:30:00.772298 [TNR] Opened connection to 105836BC/0 for ch2.3 TPTLife
2021/10/21 08:30:03.912797 [DVR] Recording for job 1634823000-101 from 105836BC ch2.3 into "TV\Garden Smart\Garden Smart S23E28 2021-10-11 Where to Start if Planning or Updating Your Garden 2021-10-21-0830.mpg" for 29m59.9938675s
2021/10/21 08:30:03.967185 [IDX] Generating video index for job 1634823000-101
2021/10/21 09:00:00.010444 [TNR] Closed connection to 105836BC/0 for ch2.3 TPTLife
2021/10/21 09:00:00.022046 [SNR] Statistics for "TV\Garden Smart\Garden Smart S23E28 2021-10-11 Where to Start if Planning or Updating Your Garden 2021-10-21-0830.mpg": ss=63%,54%-70% snq=93%,74%-100% seq=100% bps=8704194,5617440-10558080 pps=745,481-904
2021/10/21 09:00:00.289373 [DVR] Finished job 1634823000-101 Garden Smart
2021/10/21 09:00:00.308077 [DVR] Processing file-4190: TV\Garden Smart\Garden Smart S23E28 2021-10-11 Where to Start if Planning or Updating Your Garden 2021-10-21-0830.mpg
2021/10/21 09:00:00.309219 [DVR] Waiting 6h29m29.6907805s until next job 1634848170-108 Whew!
2021/10/21 09:00:00.309219 [DBG] Scheduling wake timer for scheduled recording in 6h27m59.6907805s
2021/10/21 09:00:00.962616 [DVR] Running commercial detection on file 4190 (TV\Garden Smart\Garden Smart S23E28 2021-10-11 Where to Start if Planning or Updating Your Garden 2021-10-21-0830.mpg)
2021/10/21 09:02:19.167001 [DVR] Commercial detection for Garden Smart S23E28 2021-10-11 Where to Start if Planning or Updating Your Garden 2021-10-21-0830.mpg finished with 4 markers in 2m18.2075469s.
2021/10/21 09:07:00.020473 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-21 9:00AM
2021/10/21 09:07:00.950769 [DVR] indexed 374 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:01.338720 [DVR] indexed 12 movies (4 channels) [0s fetch, 0s index]
2021/10/21 09:07:01.343366 [DVR] pruned 81 replaced airings in 0s.
2021/10/21 09:07:01.345415 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-21 3:00PM
2021/10/21 09:07:02.154697 [DVR] indexed 378 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:02.506773 [DVR] indexed 16 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:02.513617 [DVR] pruned 37 replaced airings in 0s.
2021/10/21 09:07:02.516695 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-21 9:00PM
2021/10/21 09:07:03.348334 [DVR] indexed 385 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:03.688093 [DVR] indexed 14 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:03.694925 [DVR] pruned 39 replaced airings in 0s.
2021/10/21 09:07:03.698548 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-22 3:00AM
2021/10/21 09:07:04.547677 [DVR] indexed 430 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:04.935730 [DVR] indexed 6 movies (4 channels) [0s fetch, 0s index]
2021/10/21 09:07:04.943028 [DVR] pruned 49 replaced airings in 0s.
2021/10/21 09:07:04.947192 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-22 9:00AM
2021/10/21 09:07:05.711100 [DVR] indexed 367 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:06.053375 [DVR] indexed 16 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:06.059642 [DVR] pruned 42 replaced airings in 0s.
2021/10/21 09:07:06.061716 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-22 3:00PM
2021/10/21 09:07:06.792182 [DVR] indexed 357 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:07.116421 [DVR] indexed 22 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:07.122618 [DVR] pruned 34 replaced airings in 0s.
2021/10/21 09:07:07.125189 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-22 9:00PM
2021/10/21 09:07:07.931478 [DVR] indexed 373 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:08.293552 [DVR] indexed 20 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:08.302685 [DVR] pruned 39 replaced airings in 0s.
2021/10/21 09:07:08.305242 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-23 3:00AM
2021/10/21 09:07:09.175385 [DVR] indexed 480 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:09.466662 [DVR] indexed 5 movies (2 channels) [0s fetch, 0s index]
2021/10/21 09:07:09.472371 [DVR] pruned 49 replaced airings in 0s.
2021/10/21 09:07:09.475443 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-23 9:00AM
2021/10/21 09:07:10.227319 [DVR] indexed 390 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:10.534924 [DVR] indexed 16 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:10.542173 [DVR] pruned 38 replaced airings in 0s.
2021/10/21 09:07:10.545244 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-23 3:00PM
2021/10/21 09:07:11.480723 [DVR] indexed 330 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:11.782388 [DVR] indexed 19 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:11.787777 [DVR] pruned 31 replaced airings in 0s.
2021/10/21 09:07:11.790413 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-23 9:00PM
2021/10/21 09:07:12.527586 [DVR] indexed 370 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:12.866017 [DVR] indexed 18 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:12.871691 [DVR] pruned 33 replaced airings in 0s.
2021/10/21 09:07:12.874259 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-24 3:00AM
2021/10/21 09:07:13.616748 [DVR] indexed 475 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:14.030146 [DVR] indexed 9 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:14.037375 [DVR] pruned 49 replaced airings in 0s.
2021/10/21 09:07:14.040586 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-24 9:00AM
2021/10/21 09:07:14.779394 [DVR] indexed 366 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:15.138320 [DVR] indexed 17 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:15.145630 [DVR] pruned 41 replaced airings in 0s.
2021/10/21 09:07:15.148271 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-24 3:00PM
2021/10/21 09:07:15.872655 [DVR] indexed 358 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:16.216091 [DVR] indexed 21 movies (8 channels) [0s fetch, 0s index]
2021/10/21 09:07:16.221090 [DVR] pruned 37 replaced airings in 0s.
2021/10/21 09:07:16.224091 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-24 9:00PM
2021/10/21 09:07:16.950012 [DVR] indexed 379 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:17.314820 [DVR] indexed 19 movies (8 channels) [0s fetch, 0s index]
2021/10/21 09:07:17.322821 [DVR] pruned 65 replaced airings in 0s.
2021/10/21 09:07:17.324819 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-25 3:00AM
2021/10/21 09:07:18.053615 [DVR] indexed 435 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:18.344198 [DVR] indexed 10 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:18.352993 [DVR] pruned 82 replaced airings in 0s.
2021/10/21 09:07:18.356118 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-25 9:00AM
2021/10/21 09:07:19.157526 [DVR] indexed 381 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:19.472922 [DVR] indexed 13 movies (5 channels) [0s fetch, 0s index]
2021/10/21 09:07:19.478165 [DVR] pruned 64 replaced airings in 0s.
2021/10/21 09:07:19.480747 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-25 3:00PM
2021/10/21 09:07:20.231969 [DVR] indexed 379 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:20.576606 [DVR] indexed 17 movies (8 channels) [0s fetch, 0s index]
2021/10/21 09:07:20.581780 [DVR] pruned 70 replaced airings in 0s.
2021/10/21 09:07:20.584349 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-25 9:00PM
2021/10/21 09:07:21.294771 [DVR] indexed 367 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:21.654794 [DVR] indexed 20 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:21.660450 [DVR] pruned 83 replaced airings in 0s.
2021/10/21 09:07:21.662561 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-26 3:00AM
2021/10/21 09:07:22.466760 [DVR] indexed 434 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:22.757365 [DVR] indexed 6 movies (2 channels) [0s fetch, 0s index]
2021/10/21 09:07:22.763178 [DVR] pruned 75 replaced airings in 0s.
2021/10/21 09:07:22.766308 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-26 9:00AM
2021/10/21 09:07:23.471230 [DVR] indexed 374 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:23.733207 [DVR] indexed 11 movies (4 channels) [0s fetch, 0s index]
2021/10/21 09:07:23.743310 [DVR] pruned 69 replaced airings in 0s.
2021/10/21 09:07:23.747451 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-26 3:00PM
2021/10/21 09:07:24.479712 [DVR] indexed 382 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:24.829609 [DVR] indexed 15 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:24.835279 [DVR] pruned 74 replaced airings in 0s.
2021/10/21 09:07:24.839353 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-26 9:00PM
2021/10/21 09:07:25.586124 [DVR] indexed 373 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:25.929024 [DVR] indexed 19 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:25.934859 [DVR] pruned 80 replaced airings in 0s.
2021/10/21 09:07:25.937983 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-27 3:00AM
2021/10/21 09:07:26.805280 [DVR] indexed 439 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:27.132273 [DVR] indexed 7 movies (4 channels) [0s fetch, 0s index]
2021/10/21 09:07:27.139234 [DVR] pruned 83 replaced airings in 0s.
2021/10/21 09:07:27.142489 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-27 9:00AM
2021/10/21 09:07:27.908368 [DVR] indexed 379 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:28.250166 [DVR] indexed 13 movies (5 channels) [0s fetch, 0s index]
2021/10/21 09:07:28.256916 [DVR] pruned 69 replaced airings in 0s.
2021/10/21 09:07:28.260067 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-27 3:00PM
2021/10/21 09:07:29.013200 [DVR] indexed 380 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:29.366149 [DVR] indexed 15 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:29.373684 [DVR] pruned 69 replaced airings in 0s.
2021/10/21 09:07:29.376273 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-27 9:00PM
2021/10/21 09:07:30.088975 [DVR] indexed 379 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:30.591984 [DVR] indexed 16 movies (6 channels) [0s fetch, 0s index]
2021/10/21 09:07:30.598737 [DVR] pruned 75 replaced airings in 0s.
2021/10/21 09:07:30.601299 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-28 3:00AM
2021/10/21 09:07:31.351888 [DVR] indexed 426 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:31.657197 [DVR] indexed 9 movies (4 channels) [0s fetch, 0s index]
2021/10/21 09:07:31.664465 [DVR] pruned 83 replaced airings in 0s.
2021/10/21 09:07:31.669715 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-28 9:00AM
2021/10/21 09:07:32.438291 [DVR] indexed 381 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:32.759432 [DVR] indexed 12 movies (5 channels) [0s fetch, 0s index]
2021/10/21 09:07:32.766941 [DVR] pruned 69 replaced airings in 0s.
2021/10/21 09:07:32.770117 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-28 3:00PM
2021/10/21 09:07:33.546869 [DVR] indexed 380 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:33.889530 [DVR] indexed 16 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:33.897785 [DVR] pruned 75 replaced airings in 0s.
2021/10/21 09:07:33.901967 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-28 9:00PM
2021/10/21 09:07:34.730884 [DVR] indexed 379 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:35.082934 [DVR] indexed 18 movies (7 channels) [0s fetch, 0s index]
2021/10/21 09:07:35.091933 [DVR] pruned 84 replaced airings in 0s.
2021/10/21 09:07:35.093935 [DVR] Fetching guide data for 52 stations in USA-OTA55427 @ 2021-10-29 3:00AM
2021/10/21 09:07:35.848568 [DVR] indexed 430 airings (52 channels) [0s fetch, 0s index]
2021/10/21 09:07:36.143732 [DVR] indexed 7 movies (4 channels) [0s fetch, 0s index]
2021/10/21 09:07:36.153411 [DVR] pruned 83 replaced airings in 0s.
2021/10/21 09:07:36.155973 [DVR] Fetching guide data for 52 stations in US
ok tuner shairing is now on. see the log below and I also uploaded the log from the app.
It sure would be great to get this thing working smoothly.
021/10/22 15:29:31.578954 [TNR] Opened connection to 105836BC/0 for ch9.4 BUZZR
2021/10/22 15:29:31.578954 [DVR] Recording for job 1634934570-108 from 105836BC ch9.4 into "TV\Whew!\Whew! 1979-04-23 2021-10-22-1529.mpg" for 30m58.9622639s
2021/10/22 15:29:31.623625 [IDX] Generating video index for job 1634934570-108
2021/10/22 16:00:30.012478 [SNR] Statistics for "TV\Whew!\Whew! 1979-04-23 2021-10-22-1529.mpg": ss=70%-71% snq=99%-100% seq=100% bps=2902914,601600-5340704 pps=253,54-457
2021/10/22 16:00:30.016901 [TNR] Closed connection to 105836BC/0 for ch9.4 BUZZR
2021/10/22 16:00:30.065664 [DVR] Finished job 1634934570-108 Whew!
2021/10/22 16:00:30.079894 [DVR] Processing file-4193: TV\Whew!\Whew! 1979-04-23 2021-10-22-1529.mpg
2021/10/22 16:00:30.080946 [DVR] Waiting 8h29m29.9190538s until next job 1634967000-110 Get Smart
2021/10/22 16:00:30.080946 [DBG] Scheduling wake timer for scheduled recording in 8h27m59.9190538s
2021/10/22 16:00:30.604715 [DVR] Running commercial detection on file 4193 (TV\Whew!\Whew! 1979-04-23 2021-10-22-1529.mpg)
2021/10/22 16:01:12.775889 [DVR] Commercial detection for Whew! 1979-04-23 2021-10-22-1529.mpg finished with 10 markers in 42.1735067s.
2021/10/22 18:34:25.513418 [TNR] Opened connection to 105836BC/0 for ch5.7 H & I
2021/10/22 22:31:29.473131 [SNR] Statistics for ch5.7 H & I: ss=68%,66%-75% snq=99%,77%-100% seq=99%,0%-100% bps=2432431,0-2895200 pps=215,0-1563
2021/10/22 22:31:29.516914 [T
as has been mentioned. If you run ethernet to the client, your issue will go away.
