I just don't get why there is a recordings and a library. Maybe if you have your own downloaded content it makes sense, but otherwise having two adjoining sections showing the same content in different formats is just confusing.
The recording version looks soooooo much nicer than the library section. Especially when the library section is broken up into two identical looking categories.
Instead of having recordings be a linear representation of each and every single recording, why can't it be just one box for each show. Then you click on it and it could be user sorted showing oldest or newest episode first, depending on their preference. Would be more organized that way.
And can we hide the library menu option? Too many repetitive options.
And I'm going to be a broken record, but enough with the purple. Thank God you made the background so dark it's near deep navy/black, but you insist on light purple lettering that's annoying to read, yet you use white text inside text boxes. For as brilliant as you guys are technically, you make the most annoying design choices and are so stubbornly loyal to this color scheme to the point you shut down anyone that complains about it. I truly don't get it. I do hope the competition gets better so I have better gui options or it forces you guys to open your eyes and get over some childhood Barney/Grimace love.
Sorry for the rant but some things are just truly baffling to me, and this is one of them.
