Will an SSL interfere with ChannelsDVR?
Hi. I have ChannelsDVR successfully setup on a Synology NAS DS220+. I'm also running two instances (1 in a Docker container), but only my primary has remote server (out of home access enabled). This NAS is currently unsecured so I'd like to secure it using an SSL certificate. Would that interfere in any way with DVR remote access on the primary install using https://my.channelsdvr.net? When watching TV outside my home I'd still want to use the my.channelsdvr.net URL, but for remote admin access to the NAS I'd like to use an FQDN and an SSL certificate. Just trying to anticipate any headaches with this desired setup. I'd rather not break anything that took a lot of work to setup properly. Thanks, Robert
No it won't interfere
