As noted will channels work on this TV: samsung un58mu6071. I can get it at a good price. Should I?
You will need an AppleTV, FireTV or AndroidTV attached to it.
If the TV has Android is ( not sure it does) wouldn’t I be able to load it on?
Theoretically, but that TV does not appear to be running Android TV.
It’s running the Samsung hub, that uses its own store apps, not android TV.
Thank you top all. I will pass and continue to search.
