Hi. I've been experiencing web player issues on Win10. Unraid V6.11.1. Channels-DVR 2022.10.14.2129. The video pauses, starts, then pauses. Sometimes it's immediate. Sometimes after several minutes. It's on a 1 gig wired network. Same happens on Chrome or Edge. Emby plays fine on the same machine. Here's a snippet from the log for two files that showed issues:
2022/10/17 16:56:22.039043 [ENC] Starting encoder for Jimmy Kimmel Live! S20E183 George Clooney Julia Roberts Omar Apollo 2022-10-13-2335.mpg in /shares/DVR/Streaming/file2048-ip192.168.1.205-1393819480/encoder-0-252827245 at 0 (0.000000) (encoder=libx264, resolution=720, deinterlacer=blend, bitrate=5488, segment_size=0.01)
2022/10/17 16:56:22.155829 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpegts @ 0x7bc2940] Dropped corrupted packet (stream = 1)
2022/10/17 16:56:22.156102 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpegts @ 0x7bc2940] Dropped corrupted packet (stream = 2)
2022/10/17 16:58:51.084032 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpegts @ 0x7bc2940] Dropped corrupted packet (stream = 0)
2022/10/17 17:00:39.949948 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpegts @ 0x7bc2940] Dropped corrupted packet (stream = 2)
2022/10/17 17:00:39.950241 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpegts @ 0x7bc2940] Dropped corrupted packet (stream = 0)
2022/10/17 17:06:29.480968 [HLS] ffmpeg: file2048-ip192.168.1.205: Last message repeated 2 times
2022/10/17 17:06:29.481244 [HLS] ffmpeg: file2048-ip192.168.1.205: [ac3 @ 0x7bea4c0] invalid coupling range (15 >= 10)
2022/10/17 17:06:29.481417 [HLS] ffmpeg: file2048-ip192.168.1.205: [ac3 @ 0x7bea4c0] error decoding the audio block
2022/10/17 17:06:29.481674 [HLS] ffmpeg: file2048-ip192.168.1.205: /shares/DVR/TV/Jimmy Kimmel Live!/Jimmy Kimmel Live! S20E183 George Clooney Julia Roberts Omar Apollo 2022-10-13-2335.mpg: corrupt decoded frame in stream 2
2022/10/17 17:07:18.161204 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpegts @ 0x7bc2940] Dropped corrupted packet (stream = 1)
2022/10/17 17:07:18.161452 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpegts @ 0x7bc2940] Dropped corrupted packet (stream = 2)
2022/10/17 17:07:18.161621 [HLS] ffmpeg: file2048-ip192.168.1.205: overread 9
2022/10/17 17:07:18.161744 [HLS] ffmpeg: file2048-ip192.168.1.205: [mpeg2video @ 0x7bcb3c0] Warning MVs not available
2022/10/17 17:07:18.169136 [HLS] ffmpeg: file2048-ip192.168.1.205: /shares/DVR/TV/Jimmy Kimmel Live!/Jimmy Kimmel Live! S20E183 George Clooney Julia Roberts Omar Apollo 2022-10-13-2335.mpg: corrupt decoded frame in stream 0
2022/10/17 17:07:18.360980 [ENC] Encoder stopped for Jimmy Kimmel Live! S20E183 George Clooney Julia Roberts Omar Apollo 2022-10-13-2335.mpg in /shares/DVR/Streaming/file2048-ip192.168.1.205-1393819480/encoder-0-252827245 after encoding 0 to 3362
2022/10/17 17:12:21.209165 [ENC] Starting encoder for NOVA S47E12 2020-09-30 A to Z How Writing Changed the World 2022-09-07-2100.mpg in /shares/DVR/Streaming/file1853-ip192.168.1.205-963178510/encoder-1261-396899068 at 1261 (1261.260000) (encoder=libx264, resolution=720, deinterlacer=blend, bitrate=5488, segment_size=0.01)
2022/10/17 17:12:21.319351 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 1)
2022/10/17 17:12:21.319540 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 2)
2022/10/17 17:12:21.327238 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] stream 2 : no PTS found at end of file, duration not set
2022/10/17 17:12:21.330810 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 1)
2022/10/17 17:12:21.332266 [HLS] ffmpeg: file1853-ip192.168.1.205: Last message repeated 4 times
2022/10/17 17:12:21.332389 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 2)
2022/10/17 17:12:21.332812 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 1)
2022/10/17 17:12:21.332978 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 2)
2022/10/17 17:12:21.353909 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 1)
2022/10/17 17:12:21.354087 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 2)
2022/10/17 17:21:44.973564 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 1)
2022/10/17 17:21:44.973823 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpegts @ 0x7bc2b40] Dropped corrupted packet (stream = 2)
2022/10/17 17:21:44.974013 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpeg2video @ 0x7be77c0] ac-tex damaged at 17 35
2022/10/17 17:21:44.974246 [HLS] ffmpeg: file1853-ip192.168.1.205: [mpeg2video @ 0x7be77c0] Warning MVs not available.
So it looks to me like the recordings from the HDHR 4K tuners are corrupted when being transcoded? Are these audio or video errors? Or both? These same files play without any visible issue on an Nvidia shield (direct play). This happens when using the hw or sw transcoding.
Any ideas?
Bobby
