Wrong audio track selected in web player
I'm on holiday this week and have been using the web player to watch TV in the evening. More often than not when playing back recordings, the audio description track gets selected instead of the normal audio track so I hear a description of what's happening on screen in addition to the normal audio. Is there a way to select the audio track in the web player or at the very least get it to use the normal audio track? I'm curious why this happens because the tvOS/iOS clients always select the right track, it's just the web player that gets it wrong.
Can you list which DVR version you are using, which web browser, and which version of the web browser? Are they all up-to-date?
DVR is 2021.08.17.2256 on Edge 92.0.902.67 on macOS 11.5.1, though this issue is present across different browsers and OSes. DVR is using hardware transcoding, and I'm in the UK so I wonder if there's some track selection logic that might need to be tweaked.
I'm experiencing this same issue.
Server 2021.09.18.0311. I tried in Chrome and Edge. My channels apps don't have this issue.
This issue?
I'd recommend updating to the latest dvr pre-release.
Pick a recording that has the issue and open it in MediaInfo using text mode, then copy and paste what it displays in a post here.
This is export from MediaInfo.
It only seems to be happening for ATSC3 recordings
General
Complete name : \server-pc\Channels DVR\TV\NCIS Hawai'i\NCIS Hawai'i S01E04 Paniolo 2021-10-11-2159.mpg
Format : MPEG-TS
File size : 2.18 GiB
Duration : 1 h 3 min
Overall bit rate mode : Variable
Overall bit rate : 4 890 kb/s
Movie name : NCIS
Law rating : TV-14 (LV)
FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
Video
Menu ID : 3 (0x3)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@Main
Codec ID : 36
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 (60000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Menu ID : 3 (0x3)
Format : AC-4
Format/Info : Audio Coding 4
Commercial name : Dolby AC-4
Format version : Version 2
Codec ID : 6
Sampling rate : 48.0 kHz
Frame rate : 29.970 FPS (1601.6 SPF)
Compression mode : Lossy
Delay relative to video : 1 s 968 ms
Language : Spanish
NOK : tools_metadata
I-Frame interval : 8 frames
Number of presentations : 1
NumberOfGroups : 1
Number of substreams : 1
Presentation #1 : Stereo Main
Dialogue normalization : -24.00
Loudness : Yes
Integrated loudness (speech gated) : -26.8 LKFS (Automated C or L+R)
Integrated loudness (level gated) : -23.8 LKFS
Audio Loudness Standard : Manual
Realtime loudness corrected : Yes
Dialogue corrected : Yes (Automated C or L+R)
Dynamic Range Control : Yes
Group #s : 1
Group #1 : Main
Content classifier : Main
Channel coded : Yes
Substream #s : 1
Substream #1 : Stereo
Channel mode : Stereo
Channel layout : L R
Preprocessing : Yes
Phase 90 Filer Info 2-ch : Applied
Dialogue enhancement : Yes
Enabled : Yes
Max gain : 9 dB
Channel configuration : L R
Audio #2
Menu ID : 3 (0x3)
Format : AC-4
Codec ID : 6
Delay relative to video : 2 s 2 ms
Language : English
NumberOfGroups : 1
Presentation #1 : 5.1 Main
Loudness : Yes
Integrated loudness (speech gated) : -27.3 LKFS (Automated individual front channels)
Integrated loudness (level gated) : -23.2 LKFS
Dialogue corrected : Yes (Automated individual front channels)
Downmix : Yes
LoRo center mix gain : -3.0 dB
LoRo surround mix gain : -3.0 dB
LtRt center mix gain : -3.0 dB
LtRt surround mix gain : -3.0 dB
LFE mix gain : -3 dB
Preferred downmix : Pro Logic II
Group #s : 1
Group #1 : Main
Channel coded : Yes
Substream #s : 1
Substream #1 : 5.1
Channel mode : 5.1
Channel layout : L R C LFE Ls Rs
Preprocessing : Yes
Phase 90 filter info : Not applied
Surround attenuation known : No
LFE attenuation known : Yes
Enabled : Yes
Max gain : 9 dB
Channel configuration : C
Text #1
ID : 49 (0x31)-CC1
Menu ID : 3 (0x3)
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Bit rate mode : Constant
Stream size : 0.00 Byte (0%)
CaptionServiceName : CC1
Text #2
ID : 49 (0x31)-CC3
Menu ID : 3 (0x3)
Format : EIA-608
CaptionServiceName : CC3
Text #3
Menu ID : 3 (0x3)
Format : EIA-708
Text #4
Menu ID : 3 (0x3)
Format : EIA-708
Text #5
Menu ID : 3 (0x3)
Format : EIA-708
Text #6
Menu ID : 3 (0x3)
Format : EIA-708
Text #7
Menu ID : 3 (0x3)
Format : EIA-708
Text #8
Menu ID : 3 (0x3)
Format : EIA-708
Menu
Menu ID : 3 (0x3)
List : 49 (0x31) (HEVC) / 50 (0x32) (AC-4, Spanish) / 51 (0x33) (AC-4, English) / 57 (0x39) ()
Title : NCIS
Language : / Spanish / English
I'm pretty sure the web player won't play ATSC 3.0 broadcasts with AC-4 audio, unless I missed a post somewhere. I thought that required ffmpeg transcoding.
They should play in the client apps. If you're having a problem selecting the English audio stream in a Channels client, which one?
ac4 audio in web player been working for awhile and I don't recall descriptive audio playing in the past. I remember a week or two ago I was watching some ATSC3 shows on my PC and didn't notice it. But today I did.
