Wrong days/times in Guide
At times, the indicated days/times in the program guide are completely wrong....not just a timezone shift, but days off. Yesterday, I opened the guide and the day/time for the beginning of the guide (currently showing stuff) was 2-3 days off. It also isn't a whole number of days, but days + hours. If I exited the guide and came back, it was still off but off by a different amount. I did this 3-4 times and every time it came up with different days/time.
Scrolling to the right, the offset continued to the end of the guide.
This doesn't happen all the time. Later, the times returned to being correct. I have seen this happen on 4-5 occasions since I started using Channels a couple of months ago.
This makes it really hard to look for programs in the future when the days and times are unpredictably wrong.
Using Channels on a Fire Cube TV 4K.
I had a similar problem because I was using the same channel numbers on both HD Homerun and Locast.
