Wrong Guide Data, Correct Channel
My 23.6 is a sub-channel of WUCW from Minneapolis and is Antenna TV. Channels DVR shows it as antenna TV, but it is some other guide information I can't identify. I contacted silicon dust and they say it is showing the antenna TV guide data on their end. So, is there any way it can be corrected in the Channels DVR guide?
You can click Manage Lineup and then fix the guide data for any channel using the gear icon next to it.
So, I see the pencil to manage lineup, and you can choose use current lineup or all lineups. The channel, WUCW, 23-6, Antenna TV is not on either list to choose. Is there a way to get that channel in the list so, I can select it?
You have to type antenna tv into the search box
Got it! That worked. Thanks. Channels DVR is a nice addition to our TV viewing.
