Wrong Guide info Euro cup, ESPN
ESPN and ESPN 2 shows the same game in the guide. Of course the less important match. Is there any way to manually record both despite the wrong guide info, or just the "better" game that isn't showing guide info for (UKR vs AUT)?
Click on the guide and select record on each one
Since both channels have the same guide data, I don't get that option.
Delete and recreate database. The guide will correct itself.
For future reference, how do I recreate database?
At halftime I stopped recording and manually started the recording on ESPN. Origionally it was recording on ESPN2. Info still is wrong but the game is correct now.
About 20 minutes before gametime I redownloaded all sources that carried ESPN and it didn't correct the guide info.
Simply redownloading entire guide under maintenance in the guide database solved the issue.
Individually redownloading each source did not.
