Wrong video, right audio
Very strange. Began watching Jeopardy recording while program was still recording. Found that the correct Jeopardy audio was recorded, but the video was from some other channel. Switched to the live program from Guide, and everything looked good. Checked the actual recording from .mpg file--wrong video. Any thoughts?
Recording on HdHomeRun Flex 4K to Mac mini.
Sounds like tuning issue. Is this ATSC3 ?
No. And remember, everything was fine when I switched to live from Guide. No problem on subsequent recordings.
Every time you ask the HDHR to watch, it has to figure out the correct frequency for the audio and the video and tune into that signal. There was a bug in the HDHR firmware that caused it to glitch out. Only thing you can do is try updating the firmware.
Same problem last night. Recorded "The Company You Keep" local station 7.1 ABC. None of the local stations are ATSC3 and rarely have issues recording from that station. How do I go about checking and updating the firmware? The setup is the HDHomeRun Flex 4k with Apple 4K 3rd gen and Channels DVR running on a Synology DS1819 NAS. What the HDHomeRun web page shows is 20221205 level for firmware and I see no option for updating.
Dvr web ui settings under sources click on the ip under the hdhr. This will open the hdhr page and if there’s an available update it will show one. Or you can launch the native hdhr app and it will notify you right away to upgrade if one is available. 20221205 is latest stable
Here's update instructions:
https://info.hdhomerun.com/info/update
