Xfinity Login Issue
Did Xfinity change anything recently?
I can’t successfully add anymore.
I do not have two step authentication selected.
I also created a second login.
I confirmed my login works on xfinity.com
I keep getting a “context cancelled” error.
I’ve restarted DVR, I’ve updated to latest version, etc
Thanks.
Hmm, it's working for me on both Channels & through xfinity stream app.
It is working for me never had a problem authorizing to xfinity.
Thats whats so odd. I can login to xfinity app and stream with no issues - but cannot connect to channels.
Some channels (ESPNs) were not working last night and individual scanning didn't work. So, I logged out - and now I can't xfinity to log back in.
Create another user just for channels and never use it anywhere else.
Try rebooting your shield
I did both.
-I restarted Shield first thing this morning.
-I created new login about an hour ago, still same issue.
I will try restarting Shield again when I get home. Perhaps it needs to be restarted after creating the new login. Thanks for the help.
wont let me log into my xfinity says no subscription when i am logged into xfinity stream and can watch things
"No subscription" means you need to login to your internet-only xfinity account and then turn off Auto Authentication.
I tried restarting Shield a few times - no help.
Unique login for channels
Restarted Shield multiple times
No two point authentication
Xfinity site and xfinity stream working fine
Very odd.
What model SHIELD?
Pretty sure it’s the original one, 07, with the smaller hard drive. (It’s so faded I can’t read it). Says Model number P2571.
Running most recent update.
Thing is, Xfinity was working fine for months - and worked fine as of last week.
DirecTV and Spectrum are working fine.
Still unable to login with Xfinity. Any other thoughts?
Would uninstalling and reinstalling the DVR Server app on the Shield perhaps help? I'd hate to have to reset everything, but at this point I'm not sure what else to do.
Thanks.
We need the exact error message, logs and a screenshot of the failure to investigate. Otherwise all we can do is guess.
Used username to login? Don't use email address to login
I just use the login username, not email. It was working fine until just the other day.
I will try to send logs, etc when I get home tonight.
Thanks for the help everyone!
Maybe the internet only Xfinity accounts don't have the same TVE authorization? Possibly it worked before but at some point Xfinity changed settings.
XFINITY and TVE is working just fine. I have never had a problem with it. I simply created an account just to be used for TVE. It works both on my ShieldTV and Synology.
I uninstalled and reinstalled the DVR Server App on my Shield. Now I have the most recent sable version, no longer the BETA - same issue.
This is the error message I get. Mind you, I cant actually type into it - its just a picture
2020/01/23 18:31:34 [TVE] Auth starting for Comcast_SSO as twartacus
2020/01/23 18:31:34 [TVE] action=auth mvpd=Comcast_SSO requestor=nbcentertainment
2020/01/23 18:31:37 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=Comcast_SSO&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2020/01/23 18:31:37 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2020/01/23 18:31:37 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/authorize
2020/01/23 18:31:38 [TVE] action=request type=Document method=GET url=https://login.xfinity.com/login
2020/01/23 18:31:38 [TVE] action=auth_domain domain=login.xfinity.com
2020/01/23 18:31:38 [TVE] action=wait_for_page
2020/01/23 18:31:48 [TVE] action=page_ready
2020/01/23 18:31:48 [TVE] action=wait_for_page done=true reason=page_ready
2020/01/23 18:31:48 [TVE] action=fill_form u=twartacus
2020/01/23 18:31:49 [TVE] action=wait_for_auth
2020/01/23 18:31:49 [TVE] action=request type=Document method=POST url=https://login.xfinity.com/login
2020/01/23 18:31:56 [TVE] action=page_ready
2020/01/23 18:32:01 [TVE] action=auth_timed_out
2020/01/23 18:32:01 [TVE] action=screenshot
2020/01/23 18:32:01 [TVE] action=screenshot size=66668
2020/01/23 18:32:01 [TVE] Auth failed for Comcast_SSO: chrome auth_timed_out
2020/01/23 18:36:23 [DVR] Fetching guide data for 127 stations in X-TVE @ 2020-01-23 6:30PM
2020/01/23 18:36:27 [DVR] indexed 916 airings (127 channels) [0s fetch, 3s index]
2020/01/23 18:36:28 [DVR] indexed 52 movies (21 channels) [0s fetch, 0s index]
2020/01/23 18:36:28 [DVR] Fetching guide data for 127 stations in X-TVE @ 2020-01-24 6:30AM
2020/01/23 18:36:32 [DVR] indexed 1007 airings (127 channels) [1s fetch, 2s index]
2020/01/23 18:36:33 [DVR] indexed 35 movies (16 channels) [0s fetch, 0s index]
2020/01/23 18:36:33 [DVR] pruned 50 replaced airings in 0s.
2020/01/23 18:36:33 [DVR] Fetching guide data for 127 stations in X-TVE @ 2020-01-24 6:30PM
2020/01/23 18:36:36 [DVR] indexed 888 airings (127 channels) [0s fetch, 2s index]
2020/01/23 18:36:37 [DVR] indexed 66 movies (29 channels) [0s fetch, 0s index]
2020/01/23 18:36:37 [DVR] pruned 33 replaced airings in 0s.
2020/01/23 18:36:37 [DVR] Fetching guide data for 127 stations in X-TVE @ 2020-01-25 6:30AM
2020/01/23 18:36:41 [DVR] indexed 1070 airings (127 channels) [0s fetch, 3s index]
2020/01/23 18:36:42 [DVR] indexed 53 movies (23 channels) [0s fetch, 0s index]
2020/01/23 18:36:42 [DVR] pruned 56 replaced airings in 0s.
2020/01/23 18:36:42 [DVR] Fetching guide data for 127 stations in X-TVE @ 2020-01-25 12:30PM
2020/01/23 18:36:46 [DVR] indexed 815 airings (127 channels) [0s fetch, 2s index]
2020/01/23 18:36:47 [DVR] indexed 100 movies (32 channels) [0s fetch, 0s index]
2020/01/23 18:36:47 [DVR] Fetching guide data for 127 stations in X-TVE @ 2020-01-25 6:30PM
This was working fine (and had been for months) until I noticed a few days ago.
It's an actual Xfinity cable account login, not just a streaming login.
I am just wondering if Xfinity changed something with their TVE.
-OTA, DirecTV and Spectrum working just fine
-created secondary login just for Channels (tried both)
-had most recent Channels BETA, reinstalled and now have most recent stable version
-running Nvidia Shield with most recent update
(Please understand, I'm not complaining - just trying to give as much info as I can).
Thanks for the help everyone.
