YES network sometimes doesn't work
Hey Guys, im getting the following error on the YES Network:
2019/07/25 19:32:46 [ERR] Could not start stream for TVE-Cablevision ch6205 FS-RSN-YES: TVE: fs2go: playback-scenarios.not-found-in-media
2019/07/25 19:34:01 [ERR] Failed to start stream for ch6205: TVE: fs2go: playback-scenarios.not-found-in-media
i rescanned, and still get the error.
thanks.
I was able to reproduce this. Seems to happen when certain games are one. It works on their website, so its something we should be able to fix.
This is fixed in the latest DVR build.
its down again. I am now getting this on The Michael Kay Show on version 2019.07.26.0234
2019/07/26 16:44:33 [ERR] Failed to start stream for ch6205: TVE: Stream not live
stream works on fsgo site.
thanks.
Just update to 2019.07.26.2000, still the same error.
thanks.
Can you try rescanning it to see if that helps?
That worked. now i know to try a rescan first if it keeps happening. thanks again.
