YES subscription in Channels?
YES Network just launched a new direct subscription service through the YES app. Would there be any way to add that feed to Channels DVR as a source?
Is there a webpage that allows you to login via a provider TVE credentials, and stream the network channel there? If not, then most likely not compatible with Channels via TVE.
Might work via custom Channel, if you can get the stream URL/m3u and it not have DRM or anything.
(I have never heard of "YES Network")
oh...Sports thing :stuck_out_tongue_closed_eyes: that why i not know of it, i not into sports.
Yes, I can view the live stream on a web page after authenticating. But it's not using a TVE provider. My TVE provider doesn't offer YES Network so I have a direct subscription to YES Network. Can I do anything with that?
I have tried the previous method and although i grabbed the stream link via chrome it wont open in any browser
I have noticed that as soon as i open the http://watchyesnetwork.com i see a cable login which brings me to the live feed after logging in Wonder if this change can allow Channels to add it back to the TVE side??
