YouTube TV: Cable provider authentication failed
Unfortunately, still not working for me. Same "Cable provider authentication failed" message as before. I am on version 2023.08.09.2030 running on a Synology NAS.
Logs have been submitted as ea2c0b7f-beb4-4312-9d2e-425e55614c81
I recently experienced the same issue that many other users have with YTTV and that the " Cable provider authentication failed" when trying to add source YouTube TV. I had successfully installed YouTube TV a few months ago. I deleted it from "Sources" and tried to reinstall it and got the infamous "Cable provider authentication failed" notice. I looked thru many articles and have not seen a clear resolution to this issue. I used different browsers. I am very disappointed with this . I really like the Channels DVR but if I can't get the channels I want on it, no reason in continuing to use it. If anyone has seen a "clear" resolution, please let me know.
Have you tried an authenticator to approve login as it scans?
You approve it on the first scan then rescan.
I've been using the independently created solution for Channels to get those wanted stations available.
The process has become quite challenging.
I am also still getting this error. I too setup YouTube TV a few months ago with no issue on my Synology NAS. I suspended YTTV service until football season started back up and now no matter what I do I get that "Cable provider authentication failed" error message. Tried multiple Gmail accounts, no MFA at all and can login fine on all sources including NBC. Looks like something with the Synology NAS Chrome version and from what I have read may not be resolvable.
Channels Version: 2023.08.15.0451
Logs have been submitted as dc57bcb0-b035-4ff2-a8e2-0052b13d759e
We haven't found a workable solution to the "browser or app may not be secure" error as of yet. We'll continue to investigate but it isn't easy to fix.
Try adding Channels DVR TVE to a docker container on the Synology just to see if it will authenticate.
No need to migrate anything to it, just test it by adding Youtube as a Provider.
If it works, you can replace the Channels DVR Synology package with the Channels DVR TVE docker container and keep the same port#, settings and recordings without having to migrate anything. I did this on my Synology.
I am also experiencing the same cable provider authentication failure, browser or app may not be secure. I've had the Gmail app, youtube tv app, and authenticator apps open while trying to scan, and Im not even being prompted to approve a login, so that's not going to work. I will submit logs as well but I don't imagine you'll see anything different.
Same problem here - YTTV worked fine for the past year - PI4 based and then about a week ago, I started seeing authentication failures - I removed and tried to re-add with the same errors everyone else is reporting here..
Boo hoo... I hope someone can get this to work.. or the channels developers find a work-around.
If you're waiting for someone else to submit diagnostics it might be awhile.
You could submit yours while you're waiting :smile:
Chrome Version 97 here and I finally got the dreaded "browser or app may not be secure" message. 2FA disabled.
I submitted a Diag - and a follow up support email - the response was they changed what devices are supported and there isn't much the channels folks can do.
I have been evaluating Sling and Hulu Live..
Who, YTTV or Channels DVR?
I am sorry I wasn't clearer - Channel's support said it's a YTTV change..
Didn't know Channels DVR supported a DVR install on those devices?
What does that have to do with TVE Authentication ?
Channels DVR server is the only thing that can authenticate TVE YTTV the ones you mention are Clients.
Originally it was everything but an Nvidia Shield (for YTTV) and ARM based NAS's (any Provider) that would work with TVE.
"ARM based NAS devices are not supported."
Since then users have reported using a Nvidia Shield as a server for YTTV and it working.
Now supposedly the RPi doesn't work for YTTV.
And that’s where I am with my RPi4. Dead in the water.
If you're stuck with YTTV and an RPi, sounds like it. Blame YTTV, not Channels.
Myself, I would still use Channels if TVE went away, but to each his own.
Blame YTTV
And drop them. That’s what is great about channels, provider doesn’t matter. Add a new one, delete the old. It’s so seemless, switch to Hulu or fubo or any other and be up in less than 10 min. I had issues with Spectrum TVE they didn’t want to fix (not in package, umm yes it is!!) so I kicked them and Hulu has been great since. I have no loyalty to these companies because they have no loyalty to me. If Hulu starts to mess with tve, I’m out and off to someone else.
