YouTube TV: Cable provider authentication failed
I was something interesting on my end.
I created another email on gmail and when i first tried to log in on Channels through TVE, I got prompt for a code that i don't have.
kind of a bummer.
Moved over to Fubo due to lack of TVE support on Synology.
Ok, i am on qnap so similar. It seems that the workaround on qnap or synology would be to run channels dvr on Docker. I have put a little bit of effort into it but not finding any really good information on the proper parameters and setting for running it on docker....
I've got Philo and it works on TVE.
I'm over on Fubo at present. So far so good.
I'm keeping my YTTV stuff set up on my system just for occasional testing etc.
I wish they had a combo package of Fubo plus YTTV. You can have the best of both worlds.
