4K HDR Thumbnails
I have a TV season that is in 4K Dolby Vision, and it doesn't seem to be able to get thumbnails. Do I understand it correctly that it creates the thumbnails when added to the library with ffmpeg? The files play fine, so I'm guessing the player in the client app works with the files fine. But on the server, is it because it's 4K or Dolby Vision or just HDR in general?
Update: Just to try to find out for myself, I added a 1080p Dolby Vision series and it seemed to get those thumbnails just fine. So it can't handle 4K, or could it be something wrong with the container for those files? The video codec are pretty close to the same.
The non working one:
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@Main
HDR format                               : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 1 h 5 min
Bit rate                                 : 1 885 kb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.009
Stream size                              : 882 MiB (85%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 862 cd/m2
Maximum Frame-Average Light Level        : 125 cd/m2
