I was wondering if anyone else is having an issue with some FireSticks where it constantly has the popup to "Allow USB debugging" even though I have clicked many times to "always allow from this computer" It seems the firestick forgets the adbkey? Is there a fix for this?
Definitely not.
Which specific FireStick model are we talking about here?
The Firestick 4k max
Gen 1 or Gen 2? And is this with ADBTuner or ah4c?
Gen 2 adbtuner. Also tested via windows command line
That is the one FireStick 4K model (Max Gen 2) that needs to have adb_allowed_connection_time set to 0 to prevent ADB authorization expirations, however that setting is adjusted automatically by ADBTuner.
In an ADB shell, you can confirm this if you like with:
settings get global adb_allowed_connection_time
Which should return:
0
To change it manually (which should not be needed in ADBTuner):
settings put global adb_allowed_connection_time 0
I'm going to test it later, thanks
I would definitely like to make things easier where I can, but I'd be concerned this might trigger unwanted inputs with apps that just happen to have those words in their on screen display.
I think the configurations thing needs to be grow up and not be the complicated thing it is now so I'm going to focus on that when time allows. A lot of people here are doing great work and it needs to be more discoverable.
Need a little help I am setting up ADBTuner on ONN4K Pro with Hulu. It seems to tune fine however after long periods of idle or ONN reboot it gets stuck at the "Who is watching" screen on the first tune attempt.
Do i need to set compatibility mode? Will that slow down tuning?
Not if your only issue is a "Who is watching".
Using the most recent :development tagged container, you can setup your own desired text matches to get past screens like that. Search this thread, and you should see some specifics about how to do this. Relevant hits will be from the last part of 2025 to now.
Before I go that route, I took a look and the Configuration I am using and it has this in it:
"global_options": {
"wait_for_video_playback_detection": false,
"use_fixed_delay": true,
"fixed_delay_seconds": 1,
"check_for_and_clear_whos_watching_prompts": true, <<<--- This
So It seems that that is not working. Is what I am seeing a bug of some sort?
You need to make sure the exact text in your who's watching prompt is being matched.
Thanks, the next time it happens I'll try to check that. But that brings up the following questions,
Where do I find the string(s) and how do I modify them if I need to?
It's done by creating a Custom Config with the :development tagged version of ADBTuner. Search this thread for more info on how to create one that includes custom strings to match. This capability was fairly recently added.
Here's a snippet of what the Custom Config JSON looks like:
Been playing around trying to scrape the DirecTV schedule API and had some success. Does this help you guys at all? Looks like I can grab a XML and some sort of DeepLink.
I have a good method setup through OliveTin-for-Channels that allows an ADBTuner user to grab their specific set of subscribed DTV channels, add them to ADBTuner and create a CDVR Custom Channels source.
It's pretty sweet, as it adds the correct subset of channels (including locals and RSNs), to ADBTuner and CDVR, and can be run whenever to update their specific set of channels.
Sorry, I couldn't resist. I got too far into playing with their API I had to write up a little Deeplinks server for DirecTV. Might be of little value, but fun to put together. Feed the container your username/password and it'll scrape their schedule and generate a M3U/XML (set type as STRMLINK). Creates a little webserver too (default port 8675). If nothing else, might be some good FAST channels in there. Works on Firestick deeplinks only right now (not sure of tvOS schema).
This is even better. I assume we can get this tool working with adbtuner? @bnhf
[quote="bnhf, post:3087, topic:36822"]
From the ADBTuner WebUI, click the small "View" hyperlink. In the View window, there are some basic remote control keys you can use to login to the DTV app. Repeat for each virtual tuner's streaming stick:
This is from tuner 1 on my setup:
Knowing that I can use these remote commands through the ADBTuner GUI is tremendously helpful. There are another couple commands which I could really use right now. Is there a way to use volume up and volume down? If not, @turtletank , can volume controls be added to the set of tuner "View" remote functions?
Is there a way to edit the default config file? Example i want to add a line to the text to watch for another phrase but i cant find a way to edit the default deep link compatibility code. I would prefer to edit that one then have to edit all my channels one by one to a new config that would just be a copy of the compatibility with the added line I want.
