Thank you. Where this user account came from i don't know. The primary tuner on this setup is a Firestick4K (edited this because i got mixed up what the new priorities were) which has been running fine until this week. I can, via the firestick remote, fire up the stream app and view channels. The log you are looking at was from me clicking the "preview" button on the ADBTuner Channel config for that particular channel. It won't let me manually tune a channel from teh Channels DVR lineup anymore. I also have 3 firestick4K's and a firestickHD that are doing the same thing, but I'll take a deeper look at their logs compared to what you see here.
And yes - it's just sitting on the home screen. and yes, they've all been rebooted along with the host running ADBtuner in docker-compose, and the stable image has been pulled as of today.
ADBTuner waits 3 seconds before sending a command to a sleeping device.
Specifically, if the display is off it sends an input keyevent KEYCODE_WAKEUP command, waits 3 seconds, then continues.
It looks like the app just never opens. Can you try updating to turtletank99/adbtuner:development and see if that changes anything, I'm not sure it will, but it might be helpful to be on the most recent version. We can continue troubleshooting from there after you have updated.
I'll check it out - thank you.
I'm beginning to think there's something network related goin on, but I gotta wait until the house full of teenagers is asleep and not online yelling at their friends until I can reboot the router...
Basically the same outcome. It woke up the firestick4k, but never launched the stream app.
adbtuner has been recreated
adbtuner exited with code 143
adbtuner            | Using database path: /app/.config/config.db
adbtuner            | INFO  [alembic.runtime.migration] Context impl SQLiteImpl.
adbtuner            | INFO  [alembic.runtime.migration] Will assume non-transactional DDL.
adbtuner            | INFO  [alembic.runtime.migration] Running upgrade e1f8d315f469 -> 7d4b685f175f, Add check connectivity option to tuners
adbtuner            | 2026/06/28 20:15:36 Loaded routes from file:
adbtuner            |   "/proxy/1" -> "http://192.168.31.10/ts/1_0"
adbtuner            |   "/proxy/2" -> "http://192.168.31.11/0.ts"
adbtuner            |   "/proxy/3" -> "http://192.168.31.11/12.ts"
adbtuner            |   "/proxy/4" -> "http://192.168.31.11/8.ts"
adbtuner            |   "/proxy/6" -> "http://192.168.31.11/4.ts"
adbtuner            |   "/proxy/7" -> "http://192.168.31.12/0.ts"
adbtuner            | INFO:     Started server process [10]
adbtuner            | INFO:     Waiting for application startup.
adbtuner            | 2026-06-28 20:15:42.099 - server - ADBTuner 20260531-3
adbtuner            | 2026-06-28 20:15:42.100 - schema_verification - Verifying database schema (/app/.config/config.db).
adbtuner            | 2026-06-28 20:15:42.107 - server - Database schema verification was successful.
adbtuner            | 2026/06/28 20:15:42 Received updated routes, but no changes detected.
adbtuner            | 2026-06-28 20:15:42.589 - tuner_management - Caching installed apps list for all tuners
adbtuner            | INFO:     Application startup complete.
adbtuner            | 2026-06-28 20:15:42.684 - lib.controller_pool - Pool: creating controller for tuner 3 (192.168.31.115).
adbtuner            | INFO:     Uvicorn running on http://0.0.0.0:5593 (Press CTRL+C to quit)
adbtuner            | 2026-06-28 20:15:42.964 - lib.controller_pool - Pool: creating controller for tuner 6 (192.168.31.227).
adbtuner            | 2026-06-28 20:15:43.546 - lib.controller_pool - Pool: creating controller for tuner 7 (192.168.31.80).
adbtuner            | 2026-06-28 20:15:43.903 - lib.controller_pool - Pool: creating controller for tuner 4 (192.168.31.80).
adbtuner            | 2026-06-28 20:15:44.169 - lib.controller_pool - Pool: creating controller for tuner 1 (192.168.31.64).
adbtuner            | 2026-06-28 20:15:45.146 - lib.controller_pool - Pool: creating controller for tuner 2 (192.168.31.87).
adbtuner            | 2026-06-28 20:17:12.591 - lib.controller_pool - Pool: evicting idle controller for tuner 3 (192.168.31.115).
adbtuner            | 2026-06-28 20:17:12.591 - lib.adb - [Pool 3] ADB: Closing connection - 192.168.31.115
adbtuner            | 2026-06-28 20:17:12.592 - lib.controller_pool - Pool: evicting idle controller for tuner 6 (192.168.31.227).
adbtuner            | 2026-06-28 20:17:12.593 - lib.adb - [Pool 6] ADB: Closing connection - 192.168.31.227
adbtuner            | 2026-06-28 20:17:12.594 - lib.controller_pool - Pool: evicting idle controller for tuner 7 (192.168.31.80).
adbtuner            | 2026-06-28 20:17:12.595 - lib.adb - [Pool 7] ADB: Closing connection - 192.168.31.80
adbtuner            | 2026-06-28 20:17:12.596 - lib.controller_pool - Pool: evicting idle controller for tuner 4 (192.168.31.80).
adbtuner            | 2026-06-28 20:17:12.597 - lib.adb - [Pool 4] ADB: Closing connection - 192.168.31.80
adbtuner            | 2026-06-28 20:17:12.598 - lib.controller_pool - Pool: evicting idle controller for tuner 1 (192.168.31.64).
adbtuner            | 2026-06-28 20:17:12.599 - lib.adb - [Pool 1] ADB: Closing connection - 192.168.31.64
adbtuner            | 2026-06-28 20:17:12.600 - lib.controller_pool - Pool: evicting idle controller for tuner 2 (192.168.31.87).
adbtuner            | 2026-06-28 20:17:12.601 - lib.adb - [Pool 2] ADB: Closing connection - 192.168.31.87
pluto-for-channels  | [INFO] Checking Scheduler Thread
tvapp2              |  tvapp2  ā„¹ļø [8:30:00 PM] core [schedule] ā„¹ļø <msg> Next IPTV data refresh at <schedule>  0 0 */3 * *  <nextrun>  07-01-2026 12:00 AM  <nextrunIso>  Wed Jul 01 2026 00:00:00 GMT+0000 (Coordinated Universal Time)
adbtuner            | 2026-06-28 20:30:42.701 - maintenance - Skipping keep alive tasks as it's currently the top or middle of the hour.
adbtuner            | 2026-06-28 20:54:21.526 - stream - [Tune fENVbYgYt4C5vjHmsHAQZw] 192.168.31.151:5592 | channels-dvr/2026.05.18.2126 Go-http-client/1.1 (linux-arm64)
adbtuner            | 2026-06-28 20:54:21.555 - stream - [Tune (fENVbYgYt4C5vjHmsHAQZw)] No active tuners found for MeTV Toons. Reserving a new tuner.
adbtuner            | 2026-06-28 20:54:21.558 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Attempting to reserve tuner for: ['com.xfinity.cloudtvr.tenfoot'].
adbtuner            | 2026-06-28 20:54:21.582 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Available Tuners:
adbtuner            | 2026-06-28 20:54:21.582 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Name: Firestick4K03-UN Priority: 0
adbtuner            | 2026-06-28 20:54:21.582 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Name: Firestick01 Priority: 1
adbtuner            | 2026-06-28 20:54:21.583 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Name: Firestick4K02 Priority: 1
adbtuner            | 2026-06-28 20:54:21.583 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Name: Firestick4K03 Priority: 1
adbtuner            | 2026-06-28 20:54:21.583 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Name: Firestick4K01 Priority: 2
adbtuner            | 2026-06-28 20:54:21.583 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Using first available tuner (by priority).
adbtuner            | 2026-06-28 20:54:21.583 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Reserved Tuner: Name: Firestick4K03-UN Priority: 0
adbtuner            | 2026-06-28 20:54:21.584 - stream - [Tune (fENVbYgYt4C5vjHmsHAQZw)] Tuning to MeTV Toons on Firestick4K03-UN
adbtuner            | 2026-06-28 20:54:21.588 - stream - [Tune (fENVbYgYt4C5vjHmsHAQZw)] Using channel configuration: Deep Links - Compatibility Mode (ADBTuner) (bb353259-17e0-4b38-a328-8629fb1ec2ca)
adbtuner            | 2026-06-28 20:54:21.590 - lib.controller_pool - Pool: creating controller for tuner 7 (192.168.31.80).
adbtuner            | 2026-06-28 20:54:22.167 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - input keyevent KEYCODE_WAKEUP
adbtuner            | 2026-06-28 20:54:24.100 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - pidof com.xfinity.cloudtvr.tenfoot
adbtuner            | 2026-06-28 20:54:24.289 - tuning - [Tune (fENVbYgYt4C5vjHmsHAQZw)] Using https://www.xfinity.com/stream/live/1736/7895878894359290105/METNS to load channel.
adbtuner            | 2026-06-28 20:54:24.289 - tuning - [Tune (fENVbYgYt4C5vjHmsHAQZw)] Executing pre-tune commands: [{'type': 'ADB', 'command': 'input keyevent KEYCODE_MEDIA_STOP'}, {'type': 'ADB', 'command': "am force-stop 'com.xfinity.cloudtvr.tenfoot'"}, {'type': 'ADB', 'command': 'sleep 2'}]
adbtuner            | 2026-06-28 20:54:24.290 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - input keyevent KEYCODE_MEDIA_STOP
adbtuner            | 2026-06-28 20:54:25.848 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - am force-stop 'com.xfinity.cloudtvr.tenfoot'
adbtuner            | 2026-06-28 20:54:26.030 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - sleep 2
adbtuner            | 2026-06-28 20:54:26.030 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: Sleeping for 2.0 seconds.
adbtuner            | 2026-06-28 20:54:28.030 - tuning - [Tune (fENVbYgYt4C5vjHmsHAQZw)] Executing tune commands: [{'type': 'ADB', 'command': "am start -W -a android.intent.action.VIEW -d 'https://www.xfinity.com/stream/live/1736/7895878894359290105/METNS' 'com.xfinity.cloudtvr.tenfoot'"}]
adbtuner            | 2026-06-28 20:54:28.030 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - am start -W -a android.intent.action.VIEW -d 'https://www.xfinity.com/stream/live/1736/7895878894359290105/METNS' 'com.xfinity.cloudtvr.tenfoot'
adbtuner            | 2026-06-28 20:54:28.231 - tuning - [Tune fENVbYgYt4C5vjHmsHAQZw] Starting tune match text monitoring. Match commands: [{'match_text': ["who's watching", 'choose an account', 'edit profiles'], 'commands': ['input keyevent KEYCODE_DPAD_CENTER'], 'start_checking_after_seconds': 5}]
adbtuner            | 2026-06-28 20:54:28.231 - tuning - [Tune fENVbYgYt4C5vjHmsHAQZw] Waiting 3 seconds to allow sleeping device to setup.
adbtuner            | 2026-06-28 20:54:33.247 - tuning - [Tune fENVbYgYt4C5vjHmsHAQZw] Waiting for playback start. Status: unknown
adbtuner            | 2026-06-28 20:54:40.548 - stream - [Tune fENVbYgYt4C5vjHmsHAQZw] Redirecting to stream after 19.02 seconds. Tuning is still in progress.
adbtuner            | 2026-06-28 20:54:40.551 - uvicorn.access - 192.168.31.151:0 - "GET /stream/59 HTTP/1.1" 307
adbtuner            | 2026/06/28 20:54:40 [PROXY] 192.168.31.151 -> GET "/proxy/7?requestKey=fENVbYgYt4C5vjHmsHAQZw" -> "http://192.168.31.12/0.ts"
adbtuner            | 2026-06-28 20:54:43.154 - server -
adbtuner            |
adbtuner            | --------------------------------------------------
adbtuner            | Tuner "Firestick4K03-UN" is currently in use and locked.
adbtuner            | Tune ID: N/A
adbtuner            | Channel: MeTV Toons
adbtuner            | Lock Obtained: 2026-06-28 20:54:21 (0.37 minutes ago)
adbtuner            | Last Seen: N/A
adbtuner            | Bytes Transferred: None
adbtuner            | Remote User Agent:
adbtuner            | N/A
adbtuner            | 2026-06-28 20:55:04.236 - tuner_management - [Tune fENVbYgYt4C5vjHmsHAQZw] Released tuner (7).
adbtuner            | 2026-06-28 20:55:04.237 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: Stopping media playback.
adbtuner            | 2026-06-28 20:55:04.239 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - input keyevent KEYCODE_MEDIA_STOP
adbtuner            | 2026-06-28 20:55:05.180 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] ADB: 192.168.31.80 - input keyevent KEYCODE_MEDIA_PAUSE
adbtuner            | 2026-06-28 20:55:06.170 - tuning - [Tune fENVbYgYt4C5vjHmsHAQZw] Tuning completed after 44.64 seconds. Maximum wait time exceeded. [Tune fENVbYgYt4C5vjHmsHAQZw] Display was on, application (com.xfinity.cloudtvr.tenfoot) was closed.
adbtuner            | 2026-06-28 20:55:12.023 - lib.adb - [Tune fENVbYgYt4C5vjHmsHAQZw] On screen text: 'oo fire ty  we 8) tol no.  brilliant color. game-changing ex  mini led tv brand  ā€˜source: circana llc retail tracking service tv mini led unit sales 52 we jan 3 2026 shop now  ā€œds dma == o a='
adbtuner            | 2026-06-28 20:55:12.024 - tuning - [Tune fENVbYgYt4C5vjHmsHAQZw] Text match result: Text to match: ["who's watching", 'choose an account', 'edit profiles']. Matches found: None.
adbtuner            | 2026-06-28 20:55:13.027 - tuning - [Tune fENVbYgYt4C5vjHmsHAQZw] Tuner is no longer active. Stopping tuning text match process.
It looks as though deep links are broken in the current FireTV version of the Xfinity app. I'm not a Comcast user so I can't fully test this, but I can confirm that the app just doesn't open.
Edit: updated below.
Something is not adding up about this, as Xfinity deeplinks still work fine with ah4c. I checked the version I have installed, which is 8.15.0.3646. I confirmed this is the most recent version by installing Xfinity Stream on a FireStick that hasn't had it installed before.
Let me dig in a bit further. Maybe it's something else.
I wonder if it could be related to using a different activity (com.xfinity.common.view.LaunchActivity)?
Here's a full tuning cycle debug from ah4c:
[EXECUTE] Stdout: 'Current PID for this script is 7182
Not a special channel (exit nor reboot)
Starting: Intent { act=android.intent.action.VIEW dat=https://www.xfinity.com/... cmp=com.xfinity.cloudtvr.tenfoot/com.xfinity.common.view.LaunchActivity }
bmitune.sh is exiting for 192.168.1.201:5555 with exit code 0
[EXECUTE] Stderr: '+ dvr=utheater-pc:8089
+ channelNameID=HCHD-7889068523651137105
++ echo HCHD-7889068523651137105
++ awk -F- '{print $2}'
+ channelID=7889068523651137105
++ awk -F- '{print $1}'
+ channelName=HCHD
+ specialID=HCHD
+ streamerIP=192.168.1.201:5555
+ streamerNoPort=192.168.1.201
+ adbTarget='adb -s 192.168.1.201:5555'
+ packageName=com.xfinity.cloudtvr.tenfoot
+ packageAction=com.xfinity.common.view.LaunchActivity
+ m3uName=xfinity.m3u
++ grep -B1 /play/tuner/HCHD-7889068523651137105 /opt/m3u/xfinity.m3u
++ awk -F 'channel-id="' 'NF>1 {split($2, a, "\""); print a[1]}'
+ m3uChannelID=1458
++ curl -s http://utheater-pc:8089/api/v1/channels
++ jq -r '.[] | select(.id == "1458") | .number'
+ channelNumber=1458
+ [[ false == '' ]]
+ speedMode=false
+ read -a autoCropChannels
+ trap finish EXIT
+ main
+ updateReferenceFiles
+ mkdir -p 192.168.1.201
+ [[ -f 192.168.1.201/stream_stopped ]]
+ [[ -f 192.168.1.201/last_channel ]]
+ echo 7182
+ echo 'Current PID for this script is 7182'
+ matchEncoderURL
+ case "$streamerIP" in
+ encoderURL=http://192.168.1.52:8090/stream2
+ encoderStreamNumber=stream2
+ encoderIP=192.168.1.52:8090/stream2
+ specialChannels
+ '[' HCHD = exit ']'
+ '[' HCHD = reboot ']'
+ [[ -f 192.168.1.201/adbCommunicationFail ]]
+ echo 'Not a special channel (exit nor reboot)'
+ tuneChannel
+ adb -s 192.168.1.201:5555 shell am start -n com.xfinity.cloudtvr.tenfoot/com.xfinity.common.view.LaunchActivity https://www.xfinity.com/stream/live/HCHD/7889068523651137105/HCHD
+ echo -e '#!/bin/bash\n\nwhile true; do sleep 4h; adb -s 192.168.1.201:5555 shell input keyevent KEYCODE_DPAD_DOWN; done'
+ chmod +x ./192.168.1.201/keep_watching.sh
+ [[ -n 4h ]]
+ nohup ./192.168.1.201/keep_watching.sh
+ printf '%s\n' 1810 1812 1841 1842 1846 1848 1852 1862
+ grep -qx 1458
+ finish
+ echo 'bmitune.sh is exiting for 192.168.1.201:5555 with exit code 0'
Terminated
[EXECUTE] Finished running ./scripts/firetv/xfinity/bmitune.sh in 14m24.250505231s
[EXECUTE] Stdout: 'Streaming stopped for 192.168.1.201:5555
Sleep initiated for 192.168.1.201:5555
192.168.1.201/stream_stopped written with epoch stop time
+ m3uChannelID=1458
+ [[ false == '' ]]
+ speedMode=false
+ grep -qx 1458
+ main
+ [[ -n croppedChannel ]]
+ matchEncoderURL
+ bmituneDone
+ bmitunePID=7182
++ pgrep -f 192.168.1.201/keep_watching.sh
+ keepWatchingPID=7202
++ pgrep -P 7202
+ keepWatchingCPID=7204
+ [[ -n '' ]]
+ ps -p 7182
+ [[ -n 4h ]]
+ kill 7202 7204
+ rm ./192.168.1.201/keep_watching.sh
+ [[ -n '' ]]
+ rm ./192.168.1.52/stream2.sh
rm: cannot remove './192.168.1.52/stream2.sh': No such file or directory
p
+ [[ false == \t\r\u\e ]]
+ stop='am force-stop com.xfinity.cloudtvr.tenfoot'
+ adb -s 192.168.1.201:5555 shell am force-stop com.xfinity.cloudtvr.tenfoot
2
+ echo 'Streaming stopped for 192.168.1.201:5555'
+ adbSleep
+ sleep='input keyevent KEYCODE_SLEEP'
+ adb -s 192.168.1.201:5555 shell input keyevent KEYCODE_SLEEP
+ echo 'Sleep initiated for 192.168.1.201:5555'
+ date +%s
+ echo '192.168.1.201/stream_stopped written with epoch stop time'
[EXECUTE] Finished running ./scripts/firetv/xfinity/stopbmitune.sh in 3.933105448s
[GIN-debug] Request: 100.xxx.xxx.xxx GET /play/tuner/HCHD-7889068523651137105, latency: 14m30.59648036s, status: 200
Thanks. This is helpful. Explicitly specifying the activity opens the app normally in the current version.
A custom configuration that does this should solve the issue, but I'm going to see if I can't figure out how to avoid doing that.
Thank you both again for spending time on this.
An added datapoint is that I did have 2 of my firesticks displaying a failed update screen earlier in the week - probably around the time this all started. Guess I need to turn off auto updates.
Once I get back in front of my server I'll try the older version and see what version they're running.
Ok, so for all intents (no pun intended) and purposes, they disabled deep links in 8.15+. They straight up removed everything related to them from AndroidManifest.xml.
Specifying the activity still works because presumably they didn't remove the rest of the deep link processing code from the app.
A custom ADBTuner configuration is going to be the best workaround. Something like this:
    "name": "Deep Links Compatibility Mode - Xfinity New",
    "author": "",
    "version": "0",
    "description": "Load content via deep link URLs with workaround for newer app versions.",
    "uuid": "7c9e4faf-0f4e-43ae-aee7-b2653bf02149",
    "global_options": {
        "use_fixed_delay": false,
        "fixed_delay_seconds": 0,
    "pre_tune_commands": [
        "am force-stop '||TARGET_PACKAGE_NAME||'",
        "sleep 2"
    "tune_commands": [
        "am start -W -a android.intent.action.VIEW -d '||TARGET_URL_OR_IDENTIFIER||' '||TARGET_PACKAGE_NAME||/com.xfinity.common.view.LaunchActivity'"
    "tune_match_text_commands": [
            "match_text": [
                "who's watching",
                "choose an account",
                "edit profiles"
            "commands": [
                "input keyevent KEYCODE_DPAD_CENTER"
            "start_checking_after_seconds": 5
    "post_tune_commands": [
        "input keyevent KEYCODE_HOME"
Thank you.
Is there already a config file I can edit, like here:
volumes: - /mnt/disk/adbtuner:/app/.config
of should it be a new file somewhere else?
docker-compose is still fairly new to me.
You can add it via the web interface:
http://<ip.address.to.adbtuner>:5592/configurations/new
Paste it right in here (remove what is pre-populated first).
Bummer.
At least there's still something we can work with.
I don't believe Xfinity supports user profiles, so this section can be removed -- correct?
Also, @daveasmann is using some pretty old FireSticks, so I'm thinking a second may need to be added here. In addition, can you confirm there's no reason to use a Keep Alive package with compatiblity mode? I can't think where this would make sense.
Yes, the text match section can be removed. I just copied the default ā€œcompatibility modeā€ config and added the activity. I didn’t try to optimize it in any way. If you have any suggestions I’m sure they would be appreciated. I’m not a comcast customer so I can’t go beyond ā€œdid the app openā€ lol.
And yeah, using the same app for Keep Alive (tuner level) along with a compatibility mode type configuration is counterproductive. There is no reason to keep an app open if you are just going to close it anyway before using it.
@daveasmann Please note the above couple of posts. Also, once you create your new ADBTuner Custom Config, be sure to modify each of your Xfinity channels to use it.
Excellent! Thank you both. Currently running on 2 firesticks via older versions. I'll get the custom config working on one of the other 2 and apply it to all 4.
Thanks again guys - this community is awesome!
A post was merged into an existing topic: ADBTuner: ws-scrcpy companion container. Interact with your encoder-connected streaming stick with mouse and keyboard
