I've been running the past few days without keepalive. It worked for months so I didn't mess with it, but it looks like it's not needed.
All Xfinity Stream channels are changed to the custom config. I'll report back if there are any issues. Thanks again.
@turtletank I've been using ADBTuner for well over a year now and love it. Thank you for all of the time and effort that you've put into it.
I've been having a few issues since around the first of the year and have resolved all but one that I can't seem to narrow down.
What I see is that occasionally (3 out of 5 mornings) when I start the first stream of the day, or later in the day after a long idle time, ADBTuner presents the YoutubeTV main screen as opposed to the channel requested. I also get a 504 response back sometimes as well.
This behavior seems to have started around the end of last year or the beginning of this one. Around that same time I had other issues such as buffering and pixelating which I ultimately resolved by upgrading my network switch. At about that same time though I also went from the 1X branch of your code to the 2X branch, upgraded my URayEncoder to the latest firmware and of course keeping the Unifi stack up-to-date.
As I said above I've replaced my network switch which made a huge improvement on the other issues, upgraded the URayEncoder to latest firmware, current with ADBTuner, and also upgraded to the newest Onn 4K boxes. I have keep alive enabled on each tuner enabled as well.
Any idea of what may be causing the YouTubeTV main screen to appear rather than the channel? I've run the logs thru Claude and I don't really think it knows enough to understand what might be happening but it seems to feel that I need to raise the issue to you. I can provide logs from this morning if that helps.
If you can share some logs either here, or via PM, I’d be glad to take a look and see if we can figure out the issue.
I've changed all my Osprey Deep Links to use your new format. So far, so good, will let you know.
No problem. I added to the Osprey FAQ/WiKi - DirecTV Osprey/Gemini Boxes - #4 by spammedeeper
I'm currently using a Link Pi encoder with (2) Chromecast with Google TVs. Ever since Android 14 and Google changing the ADP port, its been a struggle.
What are the go to devices people are using that have been rock solid? I primarily use it for Youtube TV tuning. Which cheap devices do people recommend? Any benefit using a Fire Stick vs say an Onn device?
I have seven FireStick 4K Max and Max Gen2 sticks running in multiple locations. They've worked great for going on three years.
FYI: There is a new version of the YouTube TV app for Android TV out in the wild (4.x.x).
It seems to be a major rewrite that replaces Google's Cobalt library with "Chrobalt." This seems to be more or less a full implementation of the Chromium browser engine (Blink) instead of the lightweight alternative it was before. The app package is significantly larger and the app consumes more RAM while running. This certainly doesn't benefit the end users with RAM and storage constrained devices. :frowning:
It seems to be a staggered release, I had to sideload it for testing on an Onn 4k Plus.
As far as ADBTuner is concerned, there is a bug in this version of the YTTV app that causes deep linked content loading to fail when the app has been sitting idle in the background for a while. The deep link opens the app, the content starts loading, and then the app forces a full reload.
I think it's basically doing the equivalent of opening a new browser tab and closing the old one. The deep link target gets lost in the process so the app just ends up sitting on the YouTube TV home screen. Since the video does actually start for a second ADBTuner detects that playback and considers it to be a successful tuning operation.
I'm looking into some options that would safely recover from this, or similar things in other apps. In the meantime, switching to a Compatibility Mode configuration in ADBTuner should keep things working with the 4.x.x app (with slower tuning times unfortunately).
Using the "Keep Device Awake" feature in ADBTuner with YTTV as the "Keep Alive Package Name," and "Keep In Foreground" enabled might sidestep the issue as well since the app could refresh itself while sitting idle. I haven't confirmed this is a fix yet though.
@bnhf I don't know if you have any hardcoded entry points for YTTV in your projects, but the entry point has changed from "MainActivity" to "ChrobaltMainActivity" in this version of the YTTV app.
@johnluber thank you for sharing your logs and other information.
Thank God a good chunk of the channels I want have native apps so I could just use that instead but yeah...they keep moving the goalposts here. Vintage Google lol
Yeah, unfortunately these complexities often make projects like this unreasonable for anyone but enthusiasts. :frowning:
Philo on FireStick is no longer working with deeplinks. And to make it more fun, it looks like when ADBTuner tries to tune the station, it permanently breaks the app. If I uninstall Philo and reinstall it works when manually using the app. When I try to use ADBTuner, the app tries to launch, but only the logo shows with a spinning circle. The app never comes up. If I quit the app, reboot the firestick and try to launch Philo again, it just has the logo and spinning circle again.
Just confirmed that I can manually open and use the Philo app multiple times after reinstalling. As soon as I use ADBTuner, the app has to be uninstalled/reinstalled.
Not getting the "break" using my ONN, but it's not directly tuning channels anymore but just a general splash page (trying to tune Destination America):
Does anyone else have automatic app updates turned off? I just checked and there is a Feb. 2026 version of the YTTV app that I can update to (on my ONN devices) - I assume that is not the new problematic version, can anyone confirm?
I will see if I can get the new version of YTTV to load one one of my Onn Full HD Sticks, see how it works. Will keep you all posted.
I have my Onn Full HD Stick setup on a my extra Link PI. What version of the YTTV Apps should I be using to test? I'm currently on 4.01.03 via the App Store.
For Destination America, here's my current link:
ADBTuner: https://www.philo.com/player/player/broadcast/Q2hhbm5lbDo2MDg1NDg4OTk2NDg0Mzk1NzY
Philo Web Link to Channel: https://www.philo.com/player/channel/Q2hhbm5lbDo2MDg1NDg4OTk2NDg0Mzk1NzY
When I paste the ADBTuner link into Chrome, it redirects me to: https://www.philo.com/player/mytv
Used to when I pasted the ADBTuner link into Chrome, it would play the channel, so something has changed even though the "channel id" hasn't changed it would appear.
I was playing around with Philo deeplinks again this morning and didn't make any progress. My links are still good, but the behavior has changed. When I paste them into Firefox, it now hits a channel landing page and doesn't start playing live. I also found that ADBTuner isn't corrupting the app, but I do have to force close it to get it working again.
For what it's worth, the bug in the newer YTTV app (4.x.x) still surfaces when using voice commands ("open espn on youtube tv"). From the device logs, that voice command more or less executes the same commands that ADBTuner would.
It's something they are certainly going to fix.
It's easy to reproduce. Just keep the app open (suspended in the background) for a good while (I've seen it after six hours, could happen in less). The first deep link, no matter how it's loaded, will fail.
YTTV is just a web app.
Neat trick: if you open https://www.youtube.com/tv/upg in Chrome you can use the tv app UI in browser.
After sitting idle for a while, I believe a server side event triggers a full reload. The URL changes to /tv/upg?hrld=1. You can actually see this when using the app normally. Sometimes you open it, you see the app UI for a millisecond, then it reloads, splash screen and all.
Summary: deep link opens app, content starts loading, full reload is initiated, the deep link context is lost. The app just stops on the home screen.
I'm not going to do anything in ADBTuner to try to fix this since it's likely the bug will eventually get fixed in the app itself. I recommend turning off automatic app updates (should always be off anyway) and sideloading an older 3.x version until this is fixed.
Alternatively, you can use a "compatibility mode" style configuration which will reload the app in advance. This slows down tuning, but should work as expected.
If you use "Keep Device Awake" along with "Keep In Foreground" and YTTV configured as the "Keep Alive Package Name" that will likely avoid the issue, but it's not guaranteed.
A custom configuration that opens the app, waits X seconds, then sends the deep link might be another possible workaround. How long to wait will probably be device dependent and this will slow down tuning as well.
I pushed a new development build of ADBTuner (20260711-1) this morning. It includes two changes.
  1. Restored a previously removed delay before playback detection starts. This should make the YTTV bug result in a failed tune instead of a successful tune that is just the app's home screen.
  2. Fixed a bug that could cause the app that could cause a "keep in foreground" app to end up in the background if an unrelated action pushed it into the background (remote command, software update, etc.)
I spent the last hour with Philo and failed to get a single deep link to work. The app accepts the deep links in the defined formats, but doesn't do anything with them. It either hangs at a loading screen for a while and then loads the app's home screen, or just loads the app's home screen directly.
I think it's just bugged. /player/player/channel/<channel_id> is still the correct format. It just doesn't work.
