This was my experience, too. I used the OliveTin "Create Native ADBTuner Channels + CDVR Custom Channels" action, including the "Native Remove" option for PBS, and it loaded both channels from the PBS json.
Thanks for the help!
I believe that OliveTin was using ADBTuner's API to add the channels one at a time which bypassed the validation (that was a bug on my end). The validation is now applied there as well but shouldn't be an issue since the package_name fields are also taken into consideration.
I'll give it a whirl later tonight to see since I got ESPN Unlimited, the true test can begin :smiley:
I'm trying to do a net new install to test this against, but keep running into this:
2026-07-28 15:00:12.570 | /app/.venv/bin/python: can't open file '/app/migrate.py': [Errno 2] No such file or directory
2026-07-28 15:00:12.985 | 2026/07/28 15:00:12 Starting proxy server with MPEG-TS null packet support
2026-07-28 15:00:12.985 | 2026/07/28 15:00:12 Loaded routes from file:
2026-07-28 15:00:23.437 | 2026/07/28 15:00:23 [PROXY] Proxy error: dial tcp 127.0.0.1:5593: connect: connection refused
2026-07-28 15:00:31.578 | INFO:     Started server process [10]
2026-07-28 15:00:31.579 | INFO:     Waiting for application startup.
2026-07-28 15:00:31.587 | 2026-07-28 15:00:31.583 - server - ADBTuner 20260728-1
2026-07-28 15:00:31.587 | 2026-07-28 15:00:31.584 - schema_verification - Verifying database schema (/app/.config/config.db).
2026-07-28 15:00:31.810 | 2026-07-28 15:00:31.809 - server - Database schema verification was successful.
2026-07-28 15:00:32.158 | ERROR:    Traceback (most recent call last):
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 1969, in _exec_single_context
2026-07-28 15:00:32.158 |     self.dialect.do_execute(
2026-07-28 15:00:32.158 |     ~~~~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.158 |         cursor, str_statement, effective_parameters, context
2026-07-28 15:00:32.158 |         ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-07-28 15:00:32.158 |     )
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/default.py", line 952, in do_execute
2026-07-28 15:00:32.158 |     cursor.execute(statement, parameters)
2026-07-28 15:00:32.158 |     ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^
2026-07-28 15:00:32.158 | sqlite3.OperationalError: no such table: app_settings
2026-07-28 15:00:32.158 | The above exception was the direct cause of the following exception:
2026-07-28 15:00:32.158 | Traceback (most recent call last):
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/starlette/routing.py", line 638, in lifespan
2026-07-28 15:00:32.158 |     async with self.lifespan_context(app) as maybe_state:
2026-07-28 15:00:32.158 |                ~~~~~~~~~~~~~~~~~~~~~^^^^^
2026-07-28 15:00:32.158 |   File "/usr/local/lib/python3.14/contextlib.py", line 214, in __aenter__
2026-07-28 15:00:32.158 |     return await anext(self.gen)
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/fastapi/routing.py", line 216, in merged_lifespan
2026-07-28 15:00:32.158 |     async with original_context(app) as maybe_original_state:
2026-07-28 15:00:32.158 |                ~~~~~~~~~~~~~~~~^^^^^
2026-07-28 15:00:32.158 |   File "/app/app/main.py", line 261, in lifespan
2026-07-28 15:00:32.158 |     migrate_file_configurations()
2026-07-28 15:00:32.158 |     ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
2026-07-28 15:00:32.158 |   File "/app/app/dependencies.py", line 532, in migrate_file_configurations
2026-07-28 15:00:32.158 |     .first()
2026-07-28 15:00:32.158 |      ~~~~~^^
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/orm/query.py", line 2766, in first
2026-07-28 15:00:32.158 |     return self.limit(1)._iter().first()  # type: ignore
2026-07-28 15:00:32.158 |            ~~~~~~~~~~~~~~~~~~~^^
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/orm/query.py", line 2864, in _iter
2026-07-28 15:00:32.158 |     result: Union[ScalarResult[_T], Result[_T]] = self.session.execute(
2026-07-28 15:00:32.158 |                                                   ~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.158 |         statement,
2026-07-28 15:00:32.158 |         params,
2026-07-28 15:00:32.158 |         execution_options={"_sa_orm_load_options": self.load_options},
2026-07-28 15:00:32.158 |         ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/orm/session.py", line 2372, in execute
2026-07-28 15:00:32.158 |     return self._execute_internal(
2026-07-28 15:00:32.158 |            ~~~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.158 |     ...<4 lines>...
2026-07-28 15:00:32.158 |         _add_event=_add_event,
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/orm/session.py", line 2270, in _execute_internal
2026-07-28 15:00:32.158 |     result: Result[Any] = compile_state_cls.orm_execute_statement(
2026-07-28 15:00:32.158 |                           ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.158 |         self,
2026-07-28 15:00:32.158 |         conn,
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/orm/context.py", line 306, in orm_execute_statement
2026-07-28 15:00:32.158 |     result = conn.execute(
2026-07-28 15:00:32.158 |         statement, params or {}, execution_options=execution_options
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 1421, in execute
2026-07-28 15:00:32.158 |     return meth(
2026-07-28 15:00:32.158 |         distilled_parameters,
2026-07-28 15:00:32.158 |         execution_options or NO_OPTIONS,
2026-07-28 15:00:32.158 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/sql/elements.py", line 526, in _execute_on_connection
2026-07-28 15:00:32.158 |     return connection._execute_clauseelement(
2026-07-28 15:00:32.158 |            ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.159 |         self, distilled_params, execution_options
2026-07-28 15:00:32.159 |         ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-07-28 15:00:32.159 |     )
2026-07-28 15:00:32.159 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 1643, in _execute_clauseelement
2026-07-28 15:00:32.159 |     ret = self._execute_context(
2026-07-28 15:00:32.159 |         dialect,
2026-07-28 15:00:32.159 |     ...<8 lines>...
2026-07-28 15:00:32.159 |         cache_hit=cache_hit,
2026-07-28 15:00:32.159 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 1848, in _execute_context
2026-07-28 15:00:32.159 |     return self._exec_single_context(
2026-07-28 15:00:32.159 |            ~~~~~~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.159 |         dialect, context, statement, parameters
2026-07-28 15:00:32.159 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 1988, in _exec_single_context
2026-07-28 15:00:32.159 |     self._handle_dbapi_exception(
2026-07-28 15:00:32.159 |     ~~~~~~~~~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.159 |         e, str_statement, effective_parameters, cursor, context
2026-07-28 15:00:32.159 |         ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-07-28 15:00:32.159 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 2365, in _handle_dbapi_exception
2026-07-28 15:00:32.159 |     raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
2026-07-28 15:00:32.159 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 1969, in _exec_single_context
2026-07-28 15:00:32.159 |     self.dialect.do_execute(
2026-07-28 15:00:32.159 |     ~~~~~~~~~~~~~~~~~~~~~~~^
2026-07-28 15:00:32.159 |         cursor, str_statement, effective_parameters, context
2026-07-28 15:00:32.159 |   File "/app/.venv/lib/python3.14/site-packages/sqlalchemy/engine/default.py", line 952, in do_execute
2026-07-28 15:00:32.159 |     cursor.execute(statement, parameters)
2026-07-28 15:00:32.159 |     ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^
2026-07-28 15:00:32.159 | sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) no such table: app_settings
2026-07-28 15:00:32.159 | [SQL: SELECT app_settings."key" AS app_settings_key, app_settings.value AS app_settings_value
2026-07-28 15:00:32.159 | FROM app_settings
2026-07-28 15:00:32.159 | WHERE app_settings."key" = ?
2026-07-28 15:00:32.159 |  LIMIT ? OFFSET ?]
2026-07-28 15:00:32.159 | [parameters: ('configurations_migrated', 1, 0)]
2026-07-28 15:00:32.159 | (Background on this error at: https://sqlalche.me/e/20/e3q8)
2026-07-28 15:00:32.162 | ERROR:    Application startup failed. Exiting.
I even did an install against latest, confirmed that was working in general, and then changed to development, but still ended up there. This is not happening against my existing Container, which is functioning just fine:
So I cloned my data volume and pointed my net new install against that. With that, I was able to finally start:
2026-07-28 15:08:28.578 | /app/.venv/bin/python: can't open file '/app/migrate.py': [Errno 2] No such file or directory
2026-07-28 15:08:28.771 | 2026/07/28 15:08:28 Starting proxy server with MPEG-TS null packet support
2026-07-28 15:08:28.784 | 2026/07/28 15:08:28 Loaded routes from file:
2026-07-28 15:08:28.784 |   "/proxy/1" -> "http://10.255.1.106:8090/hdmi1"
2026-07-28 15:08:29.849 | 2026/07/28 15:08:29 [PROXY] Proxy error: dial tcp 127.0.0.1:5593: connect: connection refused
2026-07-28 15:08:38.274 | INFO:     Started server process [9]
2026-07-28 15:08:38.279 | 2026-07-28 15:08:38.278 - server - ADBTuner 20260728-1
2026-07-28 15:08:38.279 | 2026-07-28 15:08:38.278 - schema_verification - Verifying database schema (/app/.config/config.db).
2026-07-28 15:08:38.279 | INFO:     Waiting for application startup.
2026-07-28 15:08:38.284 | 2026-07-28 15:08:38.284 - server - Database schema verification was successful.
2026-07-28 15:08:38.641 | 2026/07/28 15:08:38 Received updated routes, but no changes detected.
2026-07-28 15:08:38.676 | 2026-07-28 15:08:38.676 - tuner_management - Caching installed apps list for all tuners
2026-07-28 15:08:38.706 | 2026-07-28 15:08:38.706 - lib.controller_pool - Pool: creating controller for tuner 1 (10.255.1.168).
2026-07-28 15:08:38.708 | INFO:     Application startup complete.
2026-07-28 15:08:38.783 | INFO:     Uvicorn running on http://0.0.0.0:5593 (Press CTRL+C to quit)
And after getting going, I could confirm the import worked as expected, at least for all stations:
Thanks for this. I just pushed a new development build (20260728-2) in which you can actually start with a fresh database again. Oops.
@turtletank, would it be possible to add some type of IF conditioning inside Configurations? I have a fun one with the NFL Network in the ESPN app where only in that situation does it require an extra down press, so I'm thinking of something like:
"ABD_IF":
     "condition": "||TARGET_URL_OR_IDENTIFIER||" == "4",
     "commands": [
          "input keyevent KEYCODE_DPAD_DOWN",
          "sleep 1"
@turtletank, if you plan to make updates (add features) to how the config files get processed, would it also be possible to make ADB calls directly, or maybe a call to an external script where ADB commands could be implemented? Doing so would somewhat merge the capabilities of AH4C with the much cleaner ADBTuner app and GUI. Building a new image with ADB included is pretty easy... so this would add lots of capabilities to ADBTuner. Just a suggestion, but would appreciate your thoughts on that. Thanks.
I have a new setup using ADBtuner. The Foxone app initially plays but then pauses after 30 seconds on my Firestick 4K 2nd gen. If I use the remote I can resume playing. Not sure why it is doing that. Using LinkPi as encoder.
Any thoughts appreciated!
Thank you!
What specific Configuration are you using (one of the included configs, or is it custom)? What specific version of ADBTuner (latest or development)?
I'm using ADBtuner stable (20260723-1) - docker container/Unraid. Using included config and entered foxone://channel/fnc as a deeplink.
Update: I changed my setup to an ONN 4K plus. Same issue!
The reason I suggest the call for an external script is because I currently use the Spectrum app on a Firestick streaming to an encoder and have to create separate config files for each Spectrum channel. I was able to create a config that allows me to enter the channel number (mapped through ADB keypad), so it would lend itself nicely to being scripted with one of the ADBTuner channel fields. One of my config files is shown (just using Hallmark Channel as an example) ... so you can see how having an external script would make this very easy by adapting the 3 keyevent fields to the channel number. Also providing the script for others with a similar setup.
    "name": "Spectrum - Hallmark Channel",
    "author": "User",
    "version": "1.0",
    "description": "Spectrum - Hallmark Channel",
    "uuid": "782a44d8-7e21-4f1e-9276-809c9454152e",
    "global_options": {
        "wait_for_video_playback_detection": false,
        "use_fixed_delay": true,
        "fixed_delay_seconds": 10,
    "pre_tune_commands": [
        "input keyevent KEYCODE_HOME",
        "sleep 3",
        "am force-stop com.spectrum.stva.firetv",
        "sleep 1",
        "am start -n com.spectrum.stva.firetv/com.spectrum.stva.androidtv.ui.HostedMainActivity",
        "sleep 12"
    "tune_commands": [
        "input keyevent KEYCODE_BACK",
        "sleep 1",
        "input keyevent KEYCODE_DPAD_RIGHT",
        "sleep 1",
        "sleep 1",
        "input keyevent KEYCODE_DPAD_CENTER",
        "sleep 1",
        "input keyevent 8",
        "sleep 1",
        "input keyevent 9",
        "sleep 1",
        "input keyevent 10",
        "sleep 1",
        "sleep 1",
        "sleep 1"
    "tune_match_text_commands": [],
    "post_tune_commands": [
        "sleep 1",
        "sleep 1",
        "input keyevent KEYCODE_SLEEP"
    "timed_keep_active_commands": [],
    "source_file": "/app/.config/user_configurations/782a44d8-7e21-4f1e-9276-809c9454152e.json"
I actually have to second this.
I would really love to see a way to call external scripts through adbtuner. I think that's the standout feature of ah4c, it's the extensibility and customizability. I think the JSON configurations are very useful for keeping things simple. But once you start wanting to build something a little bit more complex, the ability to just write bash or Python could be really useful. I mean, obviously, this could be for advanced users, but this could really open up a whole plugin ecosystem for ADB Tuner.
I mean, I just built a sort of feature for ah4c using bash, effectively, wait for video playback detection just implement it in straight up bash. It works super well, and just like I kind of like that about ah4c that you can kind of just do anything, and it's like a playground, which is great for people like me who like to tinker. It's a sort of a feature because it's an external script, it's not actually part of the application.
I think this could really benefit ADBTuner just because you can have the slick interface and really easy to use configurations and repositories while also being able to tinker if you so choose.
On a side note... I upgraded from the Dec 2025 stable version to the July 2026 stable version (20260723-1) last night. Why was the ability to save config files removed? That was great for backup purposes... I'd suggest/request that feature be added back into the baseline. Thanks.
I believe the development tag, which by the way is an excellent redesign, will allow you to back up your entire configuration in one shot.
Okay, but I'm only using the stable image (and very recent 7/23/2026) and it doesn't have an option to save the config files. There is an option on the main GUI page to import/export the channels list, but I'm referring to the discrete config files. The previous version had a download json option, but this latest image doesn't have that feature. Seems like a backup/download feature should be in the stable releases as a core feature, not just the development images.
Interesting idea. In the past, @turtletank has expressed reluctance to add full scripting to ADBTuner. Although, as one looks at the evolution of ADBTuner over the last three years, it's come closer and closer to ah4c in terms of power-user features.
I'm one of the developers of ah4c, but I use both ah4c and ADBTuner, as they've been fairly well differentiated in terms of which is better suited for various tasks. Though I'd be happy to see ADBTuner expanded to include scripting and arbitrary ADB commands, and would no doubt use any expanded feature set, I find myself wondering about the future of ah4c in such a scenario.
I have total confidence and trust in @turtletank, but at the same time, I'm an open source guy at heart. Even though Channels itself is not open source, the developers have done an excellent job of providing hooks for community projects. With very few exceptions, those community projects have been open source, with each of us having the option to review and/or expand the project.
ADBTuner has been an exception, and is not open source. I know many of us have wished this were not the case, but every developer has the 100% right to decide for themselves whether they want their project to be in the public domain (though subject to licensing) or not.
There have been requests in the past for ADBTuner to become open source, and I'd like to renew that request -- especially in light of the idea of ADBTuner adding full scripting. If that happens, and I hope it does :slight_smile:, it seems like that would be an appropriate moment to deprecate ah4c. Probably the only reason to continue maintaining it at that point would be to have an open source alternative to ADBTuner.
I love ADBTuner so much. I think it's such a great piece of software. I think it's so carefully and thoughtfully designed.
I really think it's probably the best tool for tuning deep links on Android. I generally stick to ah4c because I prefer open source. This is not out of like some personal moral conviction or something like that. This is simply because I can actually contribute to a project and give back to the community, which with ADB Tuner, I am completely locked out unless I want to violate a license. It's really, again, as I say, for the love of the game and nothing more, I want to build things around the community projects here, even though I don't really have one of my own except for my little Docker container for Unraid.
So ultimately, it's up to @turtletank what he wants to do, but I again would like to renew and agree with @bnhf that open sourcing ADBTuner should be considered. Even if it was like a Polyform strict license or something where it couldn't be redistributed or anything like that, but the community could see the source code and help implement features and have them considered. Obviously, Channels is a commercial product, but the things around it aren't. And I think ADBTuner is the odd duck out that's closed source in a sea of open source.
I also want to add I know in the past people were a little rude to @turtletank about implementing features when it was briefly open source. I think if that were to happen again, those of us in the community that are actually supportive would be more than happy to put a stop to that and make sure those people are properly put in their place where they belong.
Please don't do that. I would start ah4c-ng LOL.
I know ADB Tuner is better in some ways, but there are certain things that I like about ah4c that I would want to maintain myself. It does work a little bit better with the Ospreys also. It tunes a little bit quicker.
Oh, not to mention managing things through environment variables is really nice.
