I take it back -- awk does work, and so does sed (I needed parentheses around my test command), at least on the FireStick 4K Max 2 (Android 11 based).
That's done in the Docker Compose, to set the hostname for the container itself, something like this:
services:
adbtuner:
# GitHub home for this project with setup instructions: Caution! This project is not open source, and is not available on GitHub
# Docker Hub home for this project: https://hub.docker.com/u/turtletank99
image: turtletank99/adbtuner:${TAG:-latest}
container_name: adbtuner
hostname: ${HOSTNAME:-adbtuner}
dns_search: ${DOMAIN:-localdomain} # Change to the name of your LAN's domain, which is usually local or localdomain
init: true
ports:
- ${HOST_PORT:-5592}:5592 # Use the same port number the container is using, or optionally change it if the port is already in use on your host
volumes:
- adbtuner:/app/.config
extra_hosts:
- host.docker.internal:${DOCKER_GATEWAY:-host-gateway} # host.docker.internal is generally not predefined on Linux hosts.
restart: unless-stopped
volumes:
adbtuner:
However, that hostname is only usable by other Docker containers on the same Docker network (not including the default bridge network where there's no Docker DNS).
I've never seen one of those package names change, so it seems like an unnecessary moving part to awk for it -- but I don't believe there'd be a discernable speed difference.
It seems that many of us who are testing new ADBT custom configurations change them often as new versions evolve. Is there a quick and easy way to change all the channels from a certain provider (DirecTV) to use a new or different config?
Usually when I'm testing, I'll just change the config for a few channels at a time. Sometimes I'll set different groups of channels to use different configs to compare them. Then, when I settle on which config I prefer, It would be nice to apply that selection universally to the rest of the channels.
Yes, via the new Action, as described here:
It only takes a couple of minutes to both update your ADBTuner DirecTV virtual channels to sync them with what's available in your DTV package, and to change Custom Configurations. All of the drudgery involved in managing large numbers of virtual DTV channels is gone!
This is awesome! I wasn't sure if it was mainly intended for the initial set up of DirecTV as an ADBTuner source. If it can be used for maintenance tasks for that source...that's even more awesome! Looks like I have something to fiddle around with today!
It seems that you, @anon38303228 and @turtletank have figured a way to prevent the "still watching" prompt from occuring. If that's the case, I'll try to set this up as a contender against, or supplement to the Roku Tuner Bridge I have been using for my DTV channels.
I'm eager to see how well this works with my ONN 4k boxes.
I just loaded the configuration with my onn 4k boxes and it does tune nice and fast.
Appreciate all this help with Directv. The genre pack is great especially with the free streaming services.
I saw the problem when trying to watch Cozi tv on the app.
When i applied the updated config, things seem to be doing a bit better and Cozi is tuning in properly the first time.
I just updated the configuration.
so far. good tuning. I noticed that it takes less time to tune to adult swim over Cozi tv. I've got Cozi tv playing on my phone aws i type just for testing purposes. The setup is working great and from what i can see Directv seems to be feeding a good picture to my encoder. I think the quality is a little better than Philo.
I think it would be fun to setup a free trial betwen yttv and see how fast it jumps between yttv and goes back to DTV.
I have two boxes and two encoders. Yttv always seemed t work but i think i like DTV better with the included subs to Hulu and Disneyplus.
We're basically circling back here to some fundamental issues with the DTV app -- that have been discussed previously in the ADBTuner thread, and in the ah4c thread:
As I said in the linked post, the only method I ever found to be 99.99% reliable with the DTV app was to force close it after each tuning cycle, and then when tuning again, launch the app and wait for active audio to be detected (from the previously tuned channel) before sending the new deeplink. Waiting for active audio to be detected is something that to-date, has only been possible with ah4c.
Lots of different approaches appear to work in testing, but will ultimately fail to be reliable in "production" use. I think we can all agree that we'd love to have speedy tuning, but in the end, when it comes to use with DVR software like this, reliability is king. The tuning method I described above, is not fast, but it is very reliable.
I hope you've found the answer with your latest configuration, but having been in your shoes during the couple of years I used DTV as my "daily driver", I think it's important to keep in mind that even a single digit failure rate can be frustrating when used as one of your primary TV sources -- especially for recordings.
I've been using your latest config for a few hours now, and it does look promising.
Fingers-crossed!
What I determined with this challenge is that after 4 hours of inactivity, the DTV app needs to reload. I suspect the "Are you still there?" prompt, and this problem are related, and the 4 hour inactivity timer renders the app unusable without reloading.
This was relatively easy to handle in ah4c, using its scripting capabilities, but could be trickier in ADBTuner. In ah4c, I always kept track of the last time a virtual tune was stopped for a given streaming stick, so that when the next virtual tune was initiated I could check if it was more than 4 hours previous.
I'd love to see DTV become reliable and fully functional for everyday use in ADBTuner -- so I'm rooting for you. And, will continue to do what I can to help make that happen.
On a side note though, if you ever get tired of the battle, ah4c is a great option for DTV. With your determination, and willingness to put in the time, any issue can be overcome with ah4c and a touch of Bash scripting.
Since the deeplinks for DTV were uncovered last year, there have been some significant efforts to get DTV working with ADBTuner up to the high standards set by YTTV with ADBTuner. We're not there yet, and hopefully that will change, but if it doesn't ah4c is a solid alternative.
Nothing ready to go, but since ah4c uses the M3U file directly there's no JSON or database involved.
I'm pretty sure you could go right from an ADBTuner export to an M3U file you could use with ah4c using jq.
The current standard ah4c dtvstreamdeeplinks.m3u file looks like this:
#EXTM3U
#EXTINF:-1 channel-id="4" channel-number="4" tvc-guide-stationid="25020",NBC-WTMJ
http://{{ .IPADDRESS }}/play/tuner/NBC-WTMJ~a43c615d-ce14-fb04-1ccc-6f0e87de3bcc
#EXTINF:-1 channel-id="6" channel-number="6" tvc-guide-stationid="30924",FOX-WITI
http://{{ .IPADDRESS }}/play/tuner/FOX-WITI~63846e66-2f3d-56d8-9bd2-a819daf182ca
#EXTINF:-1 channel-id="10" channel-number="10" tvc-guide-stationid="19633",PBS-WMVS
http://{{ .IPADDRESS }}/play/tuner/PBS-WMVS~6f9c68ae-cb51-9cc1-f2ea-560b2828b457
#EXTINF:-1 channel-id="12" channel-number="12" tvc-guide-stationid="32367",ABC-WISN
http://{{ .IPADDRESS }}/play/tuner/ABC-WISN~652caee6-6aa6-b4aa-49ba-584a6a1298b1
#EXTINF:-1 channel-id="18" channel-number="18" tvc-guide-stationid="35541",CW-WVTV
http://{{ .IPADDRESS }}/play/tuner/CW-WVTV~7ce2fcc2-cfbd-a78e-3455-1b66b3dfb6e8
#EXTINF:-1 channel-id="24" channel-number="24" tvc-guide-stationid="89743",MyNet-WVTV-D2
http://{{ .IPADDRESS }}/play/tuner/MyNet-WVTV-D2~24f1a3f7-644d-4082-ac29-c58effa7ad19
#EXTINF:-1 channel-id="58" channel-number="58" tvc-guide-stationid="30192",CBS-WDJT
http://{{ .IPADDRESS }}/play/tuner/CBS-WDJT~a6ec2f4f-5f44-ff82-72d1-fc88aa331ef9
#EXTINF:-1 channel-id="77" channel-number="77" tvc-guide-stationid="122696",MeTV
http://{{ .IPADDRESS }}/play/tuner/MeTV~83321f4e-2ac2-9dc4-a1fd-7b0a0f8c1e5f
#EXTINF:-1 channel-id="80" channel-number="80" tvc-guide-stationid="89994",Cozi TV
http://{{ .IPADDRESS }}/play/tuner/Cozi-TV~9fd00aad-1cc7-cf23-ba3e-bae853bd6165
#EXTINF:-1 channel-id="81" channel-number="81" tvc-guide-stationid="89922",GRIT
http://{{ .IPADDRESS }}/play/tuner/GRIT~3097b4cc-3b54-14e3-c801-796f2316040f
#EXTINF:-1 channel-id="82" channel-number="82" tvc-guide-stationid="73067",BounceTV
http://{{ .IPADDRESS }}/play/tuner/BounceTV~19a0169f-323e-b251-99e0-56b7209b4dca
#EXTINF:-1 channel-id="83" channel-number="83" tvc-guide-stationid="132748",GET
http://{{ .IPADDRESS }}/play/tuner/GET~23f0fc84-d285-c4a1-a4c9-dfb383ed77db
#EXTINF:-1 channel-id="202" channel-number="202" tvc-guide-stationid="58646",CNNHD
http://{{ .IPADDRESS }}/play/tuner/CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428
#EXTINF:-1 channel-id="204" channel-number="204" tvc-guide-stationid="10145",HLN
http://{{ .IPADDRESS }}/play/tuner/HLNHD~6d1f5d8a-9616-b2aa-fd67-190f5f108591
#EXTINF:-1 channel-id="206" channel-number="206" tvc-guide-stationid="32645",ESPN HD
http://{{ .IPADDRESS }}/play/tuner/ESPNHD~dede9246-d012-a0b5-3a0d-47e1dab9aad8
#EXTINF:-1 channel-id="207" channel-number="207" tvc-guide-stationid="16485",ESPNEWS
http://{{ .IPADDRESS }}/play/tuner/ESNHD~12a35cc1-19d8-d1c1-1fac-4ca6b264dbed
#EXTINF:-1 channel-id="208" channel-number="208" tvc-guide-stationid="60696",ESPNU HD
http://{{ .IPADDRESS }}/play/tuner/ESPNUHD~9ecd95cc-35c3-6edf-f374-ba56a30479c0
#EXTINF:-1 channel-id="209" channel-number="209" tvc-guide-stationid="45507",ESPN2 HD
http://{{ .IPADDRESS }}/play/tuner/ESPN2HD~86803936-4000-2af7-19e9-81ba8fa148d8
#EXTINF:-1 channel-id="211" channel-number="211" tvc-guide-stationid="89351",NFL Red Zone
http://{{ .IPADDRESS }}/play/tuner/NFLNRZ~16118543-23f0-cd3a-bb5b-3c97438c34f5
#EXTINF:-1 channel-id="212" channel-number="212" tvc-guide-stationid="45399",NFL Network
http://{{ .IPADDRESS }}/play/tuner/NFLHD~b7effab4-2677-a11a-6505-d5e1ef60f465
#EXTINF:-1 channel-id="213" channel-number="213" tvc-guide-stationid="62081",MLB Network
http://{{ .IPADDRESS }}/play/tuner/MLBNHD~a65b11b9-e803-3bc8-1efc-49c5dd66d689
#EXTINF:-1 channel-id="213A" channel-number="213A" tvc-guide-stationid="62085",MLB Network Alternate
http://{{ .IPADDRESS }}/play/tuner/MLBaHD~7c04b18e-9534-d6a4-dbd8-790561ee75a6
#EXTINF:-1 channel-id="215" channel-number="215" tvc-guide-stationid="58690",NHL Network HD
http://{{ .IPADDRESS }}/play/tuner/NHLHD~f70c4f77-652e-bfc0-6f4d-65f32fc3f2ba
#EXTINF:-1 channel-id="216" channel-number="216" tvc-guide-stationid="45526",NBA TV
http://{{ .IPADDRESS }}/play/tuner/NBAHD~d340c4c5-abad-9bc1-6dbc-3cd499b796a7
#EXTINF:-1 channel-id="217" channel-number="217" tvc-guide-stationid="60316",Tennis Channel HD
http://{{ .IPADDRESS }}/play/tuner/TNNSHD~f0d90008-caa2-97c8-93c3-7ff6a575486f
#EXTINF:-1 channel-id="218" channel-number="218" tvc-guide-stationid="61854",Golf Channel
http://{{ .IPADDRESS }}/play/tuner/GolfHD~2dd56923-6e9f-b6ef-a3d6-d6c0c5aa6ab0
#EXTINF:-1 channel-id="219" channel-number="219" tvc-guide-stationid="82547",FOX Sports 1
http://{{ .IPADDRESS }}/play/tuner/FS1HD~5c55c82f-c5cb-2aa5-6376-cc868d5cdc32
#EXTINF:-1 channel-id="221" channel-number="221" tvc-guide-stationid="59250",CBS Sports Network HD
http://{{ .IPADDRESS }}/play/tuner/CBSSNHD~143250f9-2f97-19ea-1070-b1b64a7589be
#EXTINF:-1 channel-id="226" channel-number="226" tvc-guide-stationid="56032",Shop LC
http://{{ .IPADDRESS }}/play/tuner/SHOPLC~c697423f-24ae-9691-cf3e-b0753f8ad23a
#EXTINF:-1 channel-id="229" channel-number="229" tvc-guide-stationid="14902",HGTV
http://{{ .IPADDRESS }}/play/tuner/HGTVHD~deaa46a3-836f-58f3-f897-73a42289a940
#EXTINF:-1 channel-id="230" channel-number="230" tvc-guide-stationid="67375",Magnolia Network
http://{{ .IPADDRESS }}/play/tuner/MAGNHD~25ad7277-733d-16f9-965d-6e80308a64fa
#EXTINF:-1 channel-id="231" channel-number="231" tvc-guide-stationid="12574",Food Network
http://{{ .IPADDRESS }}/play/tuner/foodHD~7822f08f-c09d-d890-2b46-948766f9f571
#EXTINF:-1 channel-id="232" channel-number="232" tvc-guide-stationid="68065",Cooking Channel
http://{{ .IPADDRESS }}/play/tuner/COOKHD~dcccb5d2-a567-e7a7-a1a2-c12d4b83c0c8
#EXTINF:-1 channel-id="233" channel-number="233" tvc-guide-stationid="68827",GSN HD
http://{{ .IPADDRESS }}/play/tuner/GSNHD~dd504770-d338-5864-8d11-e0ae78330990
#EXTINF:-1 channel-id="235" channel-number="235" tvc-guide-stationid="107076",Tastemade
http://{{ .IPADDRESS }}/play/tuner/TASTE~6a0016fd-74ec-7d3e-973f-da042697284d
#EXTINF:-1 channel-id="236" channel-number="236" tvc-guide-stationid="61812",E HD
http://{{ .IPADDRESS }}/play/tuner/E!HD~b4bd8603-8a28-c738-450b-b43807610760
#EXTINF:-1 channel-id="237" channel-number="237" tvc-guide-stationid="58625",Bravo
http://{{ .IPADDRESS }}/play/tuner/BRVOHD~aad256ef-1e09-f926-a05e-2591a809ffff
#EXTINF:-1 channel-id="238" channel-number="238" tvc-guide-stationid="68385",ReelzChannel HD
http://{{ .IPADDRESS }}/play/tuner/REELZHD~c3fbdc9f-44b7-76e3-23e9-cde81c5b3117
#EXTINF:-1 channel-id="239" channel-number="239" tvc-guide-stationid="71280",Sundance TV
http://{{ .IPADDRESS }}/play/tuner/SUNDHD~d94cb013-806e-43f9-c316-31ed9073b3d3
#EXTINF:-1 channel-id="240" channel-number="240" tvc-guide-stationid="62077",HSN HD
http://{{ .IPADDRESS }}/play/tuner/HSNHD~b26807c7-7513-c72e-261c-6270efc1cad4
#EXTINF:-1 channel-id="241" channel-number="241" tvc-guide-stationid="59186",Paramount TV
http://{{ .IPADDRESS }}/play/tuner/PARHD~6924fc10-8306-4009-6495-714764f0dbf6
#EXTINF:-1 channel-id="242" channel-number="242" tvc-guide-stationid="58452",USA Network
http://{{ .IPADDRESS }}/play/tuner/USAHD~28bbbe87-9c3b-5da7-4ad4-9868916b173d
#EXTINF:-1 channel-id="244" channel-number="244" tvc-guide-stationid="58623",Syfy HD
http://{{ .IPADDRESS }}/play/tuner/SyfyHD~148e9301-574b-e202-9f1d-5eaac40731ac
#EXTINF:-1 channel-id="245" channel-number="245" tvc-guide-stationid="42642",TNT HD
http://{{ .IPADDRESS }}/play/tuner/TNTHD~acf51074-6940-81d8-2355-c2eb610e0afc
#EXTINF:-1 channel-id="246" channel-number="246" tvc-guide-stationid="64490",truTV HD
http://{{ .IPADDRESS }}/play/tuner/truTVHD~e7971467-59df-3be6-5711-8b9f72b70787
#EXTINF:-1 channel-id="247" channel-number="247" tvc-guide-stationid="58515",TBS HD
http://{{ .IPADDRESS }}/play/tuner/TBSHD~ded1f9a7-a3e2-503d-7129-3e31e5257fae
#EXTINF:-1 channel-id="248" channel-number="248" tvc-guide-stationid="58574",FX HD
http://{{ .IPADDRESS }}/play/tuner/FXHD~f1281894-b977-5b3a-596d-5cf3b1b176ca
#EXTINF:-1 channel-id="249" channel-number="249" tvc-guide-stationid="62420",Comedy Central
http://{{ .IPADDRESS }}/play/tuner/COMHD~853e2bbe-abda-d6b7-26c9-69fbe2d007ef
#EXTINF:-1 channel-id="251" channel-number="251" tvc-guide-stationid="70522",Oxygen True Crime
http://{{ .IPADDRESS }}/play/tuner/OXGNHD~a7ee26db-54eb-601b-b8df-1a67ad0cff4d
#EXTINF:-1 channel-id="252" channel-number="252" tvc-guide-stationid="60150",Lifetime
http://{{ .IPADDRESS }}/play/tuner/LIFEHD~bab3ef03-eeac-b5b1-a157-1a98bf4fbbde
#EXTINF:-1 channel-id="253" channel-number="253" tvc-guide-stationid="55887",LMN HD
http://{{ .IPADDRESS }}/play/tuner/LMNHD~3d967c45-3b9b-f223-db5f-b4d7ef756744
#EXTINF:-1 channel-id="254" channel-number="254" tvc-guide-stationid="59337",AMC HD
http://{{ .IPADDRESS }}/play/tuner/AMCHD~91f974cf-5346-2c4a-47c6-ad3326597a6b
#EXTINF:-1 channel-id="256" channel-number="256" tvc-guide-stationid="64312",TCM HD
http://{{ .IPADDRESS }}/play/tuner/TCMHD~cca34ba0-ffc4-bcdd-16d1-20469ae2f1c9
#EXTINF:-1 channel-id="258" channel-number="258" tvc-guide-stationid="70253",FX Movie Channel
http://{{ .IPADDRESS }}/play/tuner/FXM~a56d1955-3f16-b9d1-a531-89755221ccf2
#EXTINF:-1 channel-id="259" channel-number="259" tvc-guide-stationid="66379",FXX HD
http://{{ .IPADDRESS }}/play/tuner/FXXHD~79dfae40-37b1-adf0-d95b-97c72f792a02
#EXTINF:-1 channel-id="260" channel-number="260" tvc-guide-stationid="59296",WE TV
http://{{ .IPADDRESS }}/play/tuner/WEHD~af87404f-791a-a30f-c3f9-484abfce0452
#EXTINF:-1 channel-id="261" channel-number="261" tvc-guide-stationid="16125",Discovery Life
http://{{ .IPADDRESS }}/play/tuner/DLIF~2c3c77b4-8941-7de6-291c-a33ad50f6504
#EXTINF:-1 channel-id="264" channel-number="264" tvc-guide-stationid="64492",BBC America
http://{{ .IPADDRESS }}/play/tuner/BBCAHD~aade5336-7457-df09-bcfe-7485240a2f8d
#EXTINF:-1 channel-id="265" channel-number="265" tvc-guide-stationid="51529",A&E HD
http://{{ .IPADDRESS }}/play/tuner/A&EHD~703b7a51-6290-4d92-6826-c52f4e23519f
#EXTINF:-1 channel-id="266" channel-number="266" tvc-guide-stationid="58988",FYI HD
http://{{ .IPADDRESS }}/play/tuner/FYIHD~2238cd22-7e7a-89d3-d219-aea6b94d292f
#EXTINF:-1 channel-id="267" channel-number="267" tvc-guide-stationid="126128",EarthxTV
http://{{ .IPADDRESS }}/play/tuner/EARTHX~76c132b0-fa3f-ac34-bc39-b0fecdc68e49
#EXTINF:-1 channel-id="269" channel-number="269" tvc-guide-stationid="57708",HISTORY
http://{{ .IPADDRESS }}/play/tuner/HISTHD~3d2a7de5-af2e-b845-da1c-17d51e5f156a
#EXTINF:-1 channel-id="271" channel-number="271" tvc-guide-stationid="65732",VICE HD
http://{{ .IPADDRESS }}/play/tuner/VICEHD~5d43cf2a-99f7-f804-499b-4409953e578d
#EXTINF:-1 channel-id="272" channel-number="272" tvc-guide-stationid="46762",LOGO HD
http://{{ .IPADDRESS }}/play/tuner/LOGOHD~cdb44de7-e993-8772-28fb-1158b49137aa
#EXTINF:-1 channel-id="273" channel-number="273" tvc-guide-stationid="68796",POP HD
http://{{ .IPADDRESS }}/play/tuner/POPHD~d7f25adf-9813-5570-bdaa-83d1aef41777
#EXTINF:-1 channel-id="274" channel-number="274" tvc-guide-stationid="69061",Ovation HD
http://{{ .IPADDRESS }}/play/tuner/OVTVHD~334adfc3-a627-41bd-7724-f313e9101697
#EXTINF:-1 channel-id="275" channel-number="275" tvc-guide-stationid="60222",QVC HD
http://{{ .IPADDRESS }}/play/tuner/QVCHD~15d2ac39-3429-e4c3-eafa-9bd6f477344d
#EXTINF:-1 channel-id="276" channel-number="276" tvc-guide-stationid="49438",National Geographic Channel
http://{{ .IPADDRESS }}/play/tuner/NGCHD~2b76c29e-325d-a699-9a6c-99bbe6a7c765
#EXTINF:-1 channel-id="277" channel-number="277" tvc-guide-stationid="59303",Travel Channel
http://{{ .IPADDRESS }}/play/tuner/TRAVHD~d1fd34a4-4dcc-dd0d-6310-6c25aabf20ff
#EXTINF:-1 channel-id="278" channel-number="278" tvc-guide-stationid="56905",DSC HD
http://{{ .IPADDRESS }}/play/tuner/DSCHD~1755a18d-4cf4-8440-8f4a-bd73849cd9d6
#EXTINF:-1 channel-id="279" channel-number="279" tvc-guide-stationid="70388",OWN HD
http://{{ .IPADDRESS }}/play/tuner/OWNHD~c88d76e7-6a4c-435c-65f2-5ea6c63a3c9e
#EXTINF:-1 channel-id="280" channel-number="280" tvc-guide-stationid="57391",TLC HD
http://{{ .IPADDRESS }}/play/tuner/TLCHD~88bbbc54-9107-45ec-26b0-a79707a87bb2
#EXTINF:-1 channel-id="281" channel-number="281" tvc-guide-stationid="31046",MotorTrend
http://{{ .IPADDRESS }}/play/tuner/MTHD~649c0044-750a-d41a-9d3d-55229567a62f
#EXTINF:-1 channel-id="282" channel-number="282" tvc-guide-stationid="57394",Animal Planet
http://{{ .IPADDRESS }}/play/tuner/APLHD~6b8b578e-eaa0-8086-4803-340763f93d36
#EXTINF:-1 channel-id="283" channel-number="283" tvc-guide-stationid="67331",Nat Geo WILD
http://{{ .IPADDRESS }}/play/tuner/NGWHD~219e6ef1-a7d1-b89d-fbb8-f190e7832bd2
#EXTINF:-1 channel-id="284" channel-number="284" tvc-guide-stationid="57390",Science
http://{{ .IPADDRESS }}/play/tuner/SCIHD~c6874cea-e0ae-8bda-80b4-a347b0e09a43
#EXTINF:-1 channel-id="285" channel-number="285" tvc-guide-stationid="65342",Investigation Discovery
http://{{ .IPADDRESS }}/play/tuner/IDHD~29ef0716-ed45-4e47-5185-d4384199b291
#EXTINF:-1 channel-id="286" channel-number="286" tvc-guide-stationid="60468",Destination America HD
http://{{ .IPADDRESS }}/play/tuner/DESTHD~d5ad3ec8-623a-b0ae-9335-a2d09fbc850c
#EXTINF:-1 channel-id="287" channel-number="287" tvc-guide-stationid="78808",American Heroes
http://{{ .IPADDRESS }}/play/tuner/AHCH~61295f1d-b338-1427-befc-e0ec881a9599
#EXTINF:-1 channel-id="289" channel-number="289" tvc-guide-stationid="74885",Disney Junior HD
http://{{ .IPADDRESS }}/play/tuner/DSJRHD~74b13512-5e2c-8c70-15d0-d1c8b9fda9b2
#EXTINF:-1 channel-id="290" channel-number="290" tvc-guide-stationid="59684",Disney Channel HD
http://{{ .IPADDRESS }}/play/tuner/DISeHD~22f13b87-4c9d-9674-f01d-328925c190e9
#EXTINF:-1 channel-id="292" channel-number="292" tvc-guide-stationid="60006",Disney XD HD
http://{{ .IPADDRESS }}/play/tuner/DXDHD~d5b8d53c-1409-d612-3436-d7bccebc4e04
#EXTINF:-1 channel-id="293" channel-number="293" tvc-guide-stationid="50338",Baby First HD
http://{{ .IPADDRESS }}/play/tuner/BABY~dc98eaf2-8e61-8222-e2a3-54dcb9e3d08a
#EXTINF:-1 channel-id="294" channel-number="294" tvc-guide-stationid="67749",Discovery Family Channel
http://{{ .IPADDRESS }}/play/tuner/DFCH~524c81fb-5d82-3ad0-c1e2-d8434692cf6b
#EXTINF:-1 channel-id="295" channel-number="295" tvc-guide-stationid="70225",Universal Kids
http://{{ .IPADDRESS }}/play/tuner/UKIDSH~d41f94b9-92a0-5134-1de2-88672cb415c5
#EXTINF:-1 channel-id="296" channel-number="296" tvc-guide-stationid="60048",Cartoon Network
http://{{ .IPADDRESS }}/play/tuner/CNeHD~2336facb-8e11-c83b-b49f-4e54682104e3
#EXTINF:-1 channel-id="298" channel-number="298" tvc-guide-stationid="21883",BOOM
http://{{ .IPADDRESS }}/play/tuner/Boom~e331455c-dfa0-7d05-2b47-2d22768394b9
#EXTINF:-1 channel-id="299" channel-number="299" tvc-guide-stationid="59432",Nickelodeon
http://{{ .IPADDRESS }}/play/tuner/NIKeHD~ed9654e0-a239-473b-2654-f45e655b183c
#EXTINF:-1 channel-id="301" channel-number="301" tvc-guide-stationid="82649",Nick Jr. HD
http://{{ .IPADDRESS }}/play/tuner/NKJRHD~e1468b46-28cd-bb84-4d8c-fa9b86fa6d6b
#EXTINF:-1 channel-id="302" channel-number="302" tvc-guide-stationid="30420",Nicktoons
http://{{ .IPADDRESS }}/play/tuner/NKTN~2e8de275-8a57-a07e-2748-45df074e06da
#EXTINF:-1 channel-id="303" channel-number="303" tvc-guide-stationid="59036",TeenNick
http://{{ .IPADDRESS }}/play/tuner/TNCK~dacae6da-950d-bc52-9e77-a120799ca097
#EXTINF:-1 channel-id="304" channel-number="304" tvc-guide-stationid="73541",TV Land
http://{{ .IPADDRESS }}/play/tuner/TVLDHD~b24b7b6f-c840-e216-e73c-7d32d9eecbda
#EXTINF:-1 channel-id="305" channel-number="305" tvc-guide-stationid="76894",ION
http://{{ .IPADDRESS }}/play/tuner/IONEHD~a6740f2c-81c8-f263-90ea-ac83df064f10
#EXTINF:-1 channel-id="307" channel-number="307" tvc-guide-stationid="91096",NewsNation
http://{{ .IPADDRESS }}/play/tuner/NwsNnHD~870c91a5-e875-37f0-3c4f-d1b41ec6b831
#EXTINF:-1 channel-id="311" channel-number="311" tvc-guide-stationid="59615",Freeform HD
http://{{ .IPADDRESS }}/play/tuner/FRFMHD~d3046aab-71b5-2d44-1b53-fcab4c9d7cad
#EXTINF:-1 channel-id="312" channel-number="312" tvc-guide-stationid="66268",Hallmark Channel
http://{{ .IPADDRESS }}/play/tuner/HALLHD~a2236f35-6af2-3c7f-bf9d-979acaec1251
#EXTINF:-1 channel-id="313" channel-number="313" tvc-guide-stationid="16604",Jewelry TV
http://{{ .IPADDRESS }}/play/tuner/JTV~7886d5c2-2559-9822-f009-3c72a2f6fb69
#EXTINF:-1 channel-id="314" channel-number="314" tvc-guide-stationid="122068",Family Movie Classics
http://{{ .IPADDRESS }}/play/tuner/FMC~57b6cb4b-1a42-2381-901c-16a2813c6492
#EXTINF:-1 channel-id="315" channel-number="315" tvc-guide-stationid="82682",QVC2
http://{{ .IPADDRESS }}/play/tuner/QVC2HD~2f0bc776-8b8f-d6a5-2123-a9c940121c63
#EXTINF:-1 channel-id="318" channel-number="318" tvc-guide-stationid="101260",QVC3
http://{{ .IPADDRESS }}/play/tuner/QVC3HD~f02bab27-3ac4-7e0c-7e6d-624804fb7c06
#EXTINF:-1 channel-id="320" channel-number="320" tvc-guide-stationid="102490",Scientology Network
http://{{ .IPADDRESS }}/play/tuner/SCNTV~5fe9e66f-bdb4-dbb1-ace0-504734ce970c
#EXTINF:-1 channel-id="323" channel-number="323" tvc-guide-stationid="73413",FETV
http://{{ .IPADDRESS }}/play/tuner/FETV~3ef9f466-918c-40c8-a141-280f8d15f623
#EXTINF:-1 channel-id="326" channel-number="326" tvc-guide-stationid="82892",Great American Family
http://{{ .IPADDRESS }}/play/tuner/GFAMHD~eaf8f979-a1ee-40e1-9162-77dc4873c9a4
#EXTINF:-1 channel-id="327" channel-number="327" tvc-guide-stationid="10138",CMT
http://{{ .IPADDRESS }}/play/tuner/CMTHD~61086ae5-48ce-8085-6d40-1da956771eba
#EXTINF:-1 channel-id="328" channel-number="328" tvc-guide-stationid="61960",TV One
http://{{ .IPADDRESS }}/play/tuner/TV1~95d012f3-9276-a155-be33-96d29a3bf2e5
#EXTINF:-1 channel-id="329" channel-number="329" tvc-guide-stationid="63236",BET HD
http://{{ .IPADDRESS }}/play/tuner/BETHD~1c362f35-5526-952d-b892-b1b8492d3d54
#EXTINF:-1 channel-id="330" channel-number="330" tvc-guide-stationid="14897",BHER
http://{{ .IPADDRESS }}/play/tuner/BHER~2cb67cc0-5cbd-c28e-5cb3-efd2c063ab05
#EXTINF:-1 channel-id="331" channel-number="331" tvc-guide-stationid="60964",MTV HD
http://{{ .IPADDRESS }}/play/tuner/MTVHD~9ec54b53-8d07-7efc-99a7-349057b95eed
#EXTINF:-1 channel-id="332" channel-number="332" tvc-guide-stationid="75077",MTV2 HD
http://{{ .IPADDRESS }}/play/tuner/MTV2HD~721ab65b-5333-8c23-4a03-3fff869176c9
#EXTINF:-1 channel-id="333" channel-number="333" tvc-guide-stationid="59444",IFC HD
http://{{ .IPADDRESS }}/play/tuner/IFCHD~156dda5e-4d82-707a-ee92-cd9fd017f425
#EXTINF:-1 channel-id="335" channel-number="335" tvc-guide-stationid="60046",VH1 HD
http://{{ .IPADDRESS }}/play/tuner/VH1HD~f4d9239f-9378-1beb-9ab3-23c07a0b1473
#EXTINF:-1 channel-id="336" channel-number="336" tvc-guide-stationid="22561",MTVClassic
http://{{ .IPADDRESS }}/play/tuner/MTVC~2f3603ca-cc66-e8b0-b2da-7c88d527c969
#EXTINF:-1 channel-id="338" channel-number="338" tvc-guide-stationid="44940",UPTV
http://{{ .IPADDRESS }}/play/tuner/UPTV~ce75e450-1ad3-1794-1b74-351de95ea6ad
#EXTINF:-1 channel-id="339" channel-number="339" tvc-guide-stationid="59116",Fuse HD
http://{{ .IPADDRESS }}/play/tuner/fuseHD~5ba91416-92dc-84ab-73fb-c7e10f4620e3
#EXTINF:-1 channel-id="340" channel-number="340" tvc-guide-stationid="28506",AXSTV
http://{{ .IPADDRESS }}/play/tuner/AXSTV~d0c3c9df-90af-6f4a-5ad0-ab0e0d646dd5
#EXTINF:-1 channel-id="341" channel-number="341" tvc-guide-stationid="110289",Cleo TV
http://{{ .IPADDRESS }}/play/tuner/CLEOTV~abb3ce13-34f9-a681-7a07-ccee20166ee1
#EXTINF:-1 channel-id="342" channel-number="342" tvc-guide-stationid="132272",theGrio
http://{{ .IPADDRESS }}/play/tuner/GRIOTV~bdc5570f-ff4d-776f-157d-cf398c4d0853
#EXTINF:-1 channel-id="345" channel-number="345" tvc-guide-stationid="63717",RFD-TV
http://{{ .IPADDRESS }}/play/tuner/RFDTV~8653742c-ddfd-32d3-e9c9-8c3489892ff6
#EXTINF:-1 channel-id="346" channel-number="346" tvc-guide-stationid="89690",BBC News
http://{{ .IPADDRESS }}/play/tuner/BBCN~2d96572a-55c8-828a-2430-66f99477d46a
#EXTINF:-1 channel-id="347" channel-number="347" tvc-guide-stationid="114934",The First
http://{{ .IPADDRESS }}/play/tuner/TheFirst~4bdf80f2-d09d-45d5-b98a-86da258f373e
#EXTINF:-1 channel-id="349" channel-number="349" tvc-guide-stationid="97163",Newsmax TV
http://{{ .IPADDRESS }}/play/tuner/NEWSMXH~533f3fad-e91d-5cbf-6f80-82db799e4953
#EXTINF:-1 channel-id="350" channel-number="350" tvc-guide-stationid="10161",C-SPAN
http://{{ .IPADDRESS }}/play/tuner/CSP1~c167f6c4-9128-4043-d798-50a8df3f29de
#EXTINF:-1 channel-id="351" channel-number="351" tvc-guide-stationid="10162",C-SPAN2
http://{{ .IPADDRESS }}/play/tuner/CSP2~49943603-c8bb-1a02-9621-15c8e95ecf7c
#EXTINF:-1 channel-id="353" channel-number="353" tvc-guide-stationid="71799",Bloomberg TV
http://{{ .IPADDRESS }}/play/tuner/BTVHD~862d91ba-d234-e4bc-1caa-79726755fd67
#EXTINF:-1 channel-id="354" channel-number="354" tvc-guide-stationid="109333",Cheddar News
http://{{ .IPADDRESS }}/play/tuner/CHDR~3180919e-9228-678f-baa7-88a09c369a95
#EXTINF:-1 channel-id="355" channel-number="355" tvc-guide-stationid="58780",CNBC HD
http://{{ .IPADDRESS }}/play/tuner/CNBCHD~a2ce2e53-bc11-775d-b070-e3c2d4a62d99
#EXTINF:-1 channel-id="356" channel-number="356" tvc-guide-stationid="64241",MSNBC
http://{{ .IPADDRESS }}/play/tuner/MSNBC~6ea83d29-e16f-7ab5-397e-6efb32bbcba9
#EXTINF:-1 channel-id="357" channel-number="357" tvc-guide-stationid="26849",CNBC World
http://{{ .IPADDRESS }}/play/tuner/CNBW~5d12e358-4ec1-3905-b5fd-f7fca4700aa6
#EXTINF:-1 channel-id="358" channel-number="358" tvc-guide-stationid="10146",CNNi HD
http://{{ .IPADDRESS }}/play/tuner/CNNiHD~ad9a7dfd-d780-1be2-adf2-a449399254f1
#EXTINF:-1 channel-id="359" channel-number="359" tvc-guide-stationid="58718",Fox Business Network
http://{{ .IPADDRESS }}/play/tuner/FBNHD~b0129946-46f3-f80f-42ea-315f64eeaac0
#EXTINF:-1 channel-id="360" channel-number="360" tvc-guide-stationid="60179",Fox News Channel
http://{{ .IPADDRESS }}/play/tuner/FNCHD~5f3323ab-7390-8fcc-177f-bf9cc8000bcf
#EXTINF:-1 channel-id="361" channel-number="361" tvc-guide-stationid="91994",AccuWeather
http://{{ .IPADDRESS }}/play/tuner/ACCUHD~dc033f1c-cc4a-adb2-fc2e-9188dc2d36ec
#EXTINF:-1 channel-id="362" channel-number="362" tvc-guide-stationid="58812",The Weather Channel HD
http://{{ .IPADDRESS }}/play/tuner/WEAHD~171bd2ee-b0d3-da59-a26a-231e199a438c
#EXTINF:-1 channel-id="363" channel-number="363" tvc-guide-stationid="93141",FOXWX
http://{{ .IPADDRESS }}/play/tuner/FOXWX~ecd16979-bf5c-6f24-2575-11788b27f387
#EXTINF:-1 channel-id="364" channel-number="364" tvc-guide-stationid="82773",INSPHD
http://{{ .IPADDRESS }}/play/tuner/INSPHD~175ff6e3-db6f-1f74-327a-ac998f93b987
#EXTINF:-1 channel-id="369" channel-number="369" tvc-guide-stationid="87001",Daystar HD
http://{{ .IPADDRESS }}/play/tuner/DSTRHD~6ee7980c-e134-7e7a-7bd0-ddc88fb558cb
#EXTINF:-1 channel-id="381" channel-number="381" tvc-guide-stationid="97409",Aspire HD
http://{{ .IPADDRESS }}/play/tuner/ASPHD~63976b4a-449a-c192-ff84-10c5d0c18fd2
#EXTINF:-1 channel-id="382" channel-number="382" tvc-guide-stationid="82470",Comedy TV
http://{{ .IPADDRESS }}/play/tuner/COMTVH~ca96e2f7-a27a-f202-cb2d-31975539c9e3
#EXTINF:-1 channel-id="383" channel-number="383" tvc-guide-stationid="78850",Justice Central HD
http://{{ .IPADDRESS }}/play/tuner/JCHD~cf7d17e0-f70e-9775-73a4-bd109035b169
#EXTINF:-1 channel-id="384" channel-number="384" tvc-guide-stationid="83098",Revolt HD
http://{{ .IPADDRESS }}/play/tuner/RVLTHD~541dd341-6a6d-19e4-58cf-b1d6469c4c05
#EXTINF:-1 channel-id="385" channel-number="385" tvc-guide-stationid="110477",Heroes & Icons
http://{{ .IPADDRESS }}/play/tuner/H&I~3e228444-bc03-2b53-fe94-311f35388702
#EXTINF:-1 channel-id="386" channel-number="386" tvc-guide-stationid="72094",FM HD
http://{{ .IPADDRESS }}/play/tuner/FM HD~953bc9f7-4dc5-93b4-8052-2a3ba1cfe4af
#EXTINF:-1 channel-id="387" channel-number="387" tvc-guide-stationid="71294",RECIPE
http://{{ .IPADDRESS }}/play/tuner/RECIPE~74271fce-8ac1-6eed-e9ab-3a25833e0f85
#EXTINF:-1 channel-id="402" channel-number="402" tvc-guide-stationid="68049",Univision
http://{{ .IPADDRESS }}/play/tuner/UNIeHD~91e8d5f2-ef1b-d3c5-17e7-cb3da2da015b
#EXTINF:-1 channel-id="404" channel-number="404" tvc-guide-stationid="68367",Galavision
http://{{ .IPADDRESS }}/play/tuner/GALAHD~f2cc0b38-5662-8586-4358-4e6746e76bb2
#EXTINF:-1 channel-id="408" channel-number="408" tvc-guide-stationid="68040",UniMas
http://{{ .IPADDRESS }}/play/tuner/UMasHD~3b2dc438-4244-ecf9-a2f6-f967c524712c
#EXTINF:-1 channel-id="410" channel-number="410" tvc-guide-stationid="91588",UNIVERSO
http://{{ .IPADDRESS }}/play/tuner/UVSOHD~d51f7b37-e63c-5d6d-3222-c237108f1d28
#EXTINF:-1 channel-id="464" channel-number="464" tvc-guide-stationid="77033",TUDN HD
http://{{ .IPADDRESS }}/play/tuner/TUDNHD~4e32e1d2-6ed0-e6fb-b3a0-f4c409ee7799
#EXTINF:-1 channel-id="535" channel-number="535" tvc-guide-stationid="36225",STARZ ENCORE East
http://{{ .IPADDRESS }}/play/tuner/SENCHD~b9ddc1ac-7daf-5f96-9817-5c2c142bfbb7
#EXTINF:-1 channel-id="536" channel-number="536" tvc-guide-stationid="17125",STARZ ENCORE West
http://{{ .IPADDRESS }}/play/tuner/SENw~97d47e36-15d9-6ea9-596b-de55223b9689
#EXTINF:-1 channel-id="537" channel-number="537" tvc-guide-stationid="14764",STARZ ENCORE Classic
http://{{ .IPADDRESS }}/play/tuner/SECL~18b2939c-782e-e13d-e764-297f9edd0238
#EXTINF:-1 channel-id="538" channel-number="538" tvc-guide-stationid="102906",STARZ ENCORE Westerns
http://{{ .IPADDRESS }}/play/tuner/SEWS~7a0cf3c9-df1a-d67f-2cfd-c31c23d42773
#EXTINF:-1 channel-id="539" channel-number="539" tvc-guide-stationid="14766",STARZ ENCORE Suspense
http://{{ .IPADDRESS }}/play/tuner/SESU~71fa3714-c586-f978-bc41-a9abbf696c7a
#EXTINF:-1 channel-id="540" channel-number="540" tvc-guide-stationid="14870",STARZ ENCORE Black
http://{{ .IPADDRESS }}/play/tuner/SEBK~5c48e0e5-2d7d-e713-9165-5dcb43014173
#EXTINF:-1 channel-id="541" channel-number="541" tvc-guide-stationid="72015",STARZ ENCORE Action
http://{{ .IPADDRESS }}/play/tuner/SEACHD~d2d065bf-aac0-7ed9-bdc5-35a713bccca8
#EXTINF:-1 channel-id="542" channel-number="542" tvc-guide-stationid="102903",STARZ ENCORE Family
http://{{ .IPADDRESS }}/play/tuner/SEFM~1dd535f5-7229-7230-2ae5-44f0b5da59d9
#EXTINF:-1 channel-id="564" channel-number="564" tvc-guide-stationid="105723",HFM
http://{{ .IPADDRESS }}/play/tuner/HFMHD~a19bb823-2d6a-925b-6e8a-d94f3610813b
#EXTINF:-1 channel-id="565" channel-number="565" tvc-guide-stationid="46710",Hallmark Mystery
http://{{ .IPADDRESS }}/play/tuner/HMYSHD~d120a585-8155-4df6-b294-2808d6e3f640
#EXTINF:-1 channel-id="566" channel-number="566" tvc-guide-stationid="33668",HDNM
http://{{ .IPADDRESS }}/play/tuner/HDNM~427146c7-ba72-f092-5c39-a973864c1429
#EXTINF:-1 channel-id="570" channel-number="570" tvc-guide-stationid="58532",Smithsonian Channel HD
http://{{ .IPADDRESS }}/play/tuner/SMTHHD~1653bae3-dad0-8d4f-7524-8090a1a46e86
#EXTINF:-1 channel-id="571" channel-number="571" tvc-guide-stationid="61621",CIHD
http://{{ .IPADDRESS }}/play/tuner/CIHD~e9009898-3c52-499b-ccaf-d02581e11039
#EXTINF:-1 channel-id="573" channel-number="573" tvc-guide-stationid="67454",Shorts TV HD
http://{{ .IPADDRESS }}/play/tuner/SHRTTV~24c133b3-ae88-b1b2-efdb-357127a9d1d7
#EXTINF:-1 channel-id="602" channel-number="602" tvc-guide-stationid="21345",FanDuel TV
http://{{ .IPADDRESS }}/play/tuner/FDTV~cbad9aaa-dacc-3f9a-e799-5cbd192a6744
#EXTINF:-1 channel-id="604" channel-number="604" tvc-guide-stationid="60111",Pursuit Channel
http://{{ .IPADDRESS }}/play/tuner/PRST~aefee661-f332-a0e1-9232-17775d8eb624
#EXTINF:-1 channel-id="605" channel-number="605" tvc-guide-stationid="33930",Sportsman Channel
http://{{ .IPADDRESS }}/play/tuner/SPMNHD~c0e8a1c8-61fb-6d94-7023-bd57672fea7a
#EXTINF:-1 channel-id="610" channel-number="610" tvc-guide-stationid="49466",BIG10HD
http://{{ .IPADDRESS }}/play/tuner/BIG10HD~6e59cfb6-e9cf-f265-1fc3-d8fb0085b829
#EXTINF:-1 channel-id="611" channel-number="611" tvc-guide-stationid="89714",SEC Network
http://{{ .IPADDRESS }}/play/tuner/SECHD~59806c1a-3da5-504b-ad47-fd7c44397445
#EXTINF:-1 channel-id="612" channel-number="612" tvc-guide-stationid="111871",ACC Network
http://{{ .IPADDRESS }}/play/tuner/ACCNHD~a39b5a6b-fcba-4d31-53be-12190003e171
#EXTINF:-1 channel-id="618" channel-number="618" tvc-guide-stationid="59305",FOX Sports 2
http://{{ .IPADDRESS }}/play/tuner/FS2HD~996701b2-525f-4b9e-ba56-222e80ff45ac
#EXTINF:-1 channel-id="623" channel-number="623" tvc-guide-stationid="8981",Next Level Sports HD
http://{{ .IPADDRESS }}/play/tuner/NXT-HD~3b0c3d09-1b7f-eb8e-cc5a-451bafbfc1b5
#EXTINF:-1 channel-id="625" channel-number="625" tvc-guide-stationid="3291",Willow HD
http://{{ .IPADDRESS }}/play/tuner/WILLOW~9d3706a3-90cb-f05d-4791-ea4013d5e994
#EXTINF:-1 channel-id="626" channel-number="626" tvc-guide-stationid="3292",Willow Xtra
http://{{ .IPADDRESS }}/play/tuner/WILLXT~28ae8df2-4955-4e64-e9dd-6dbf9ee2a9e2
#EXTINF:-1 channel-id="628" channel-number="628" tvc-guide-stationid="10996",NESN
http://{{ .IPADDRESS }}/play/tuner/NESNOM~31f3edfb-3e42-f36e-4ac4-e6399f1d11d6
#EXTINF:-1 channel-id="630" channel-number="630" tvc-guide-stationid="11104",NBC Sports Boston
http://{{ .IPADDRESS }}/play/tuner/NBSBOM~654cd6e9-85c7-aae8-ca96-d3a8e0e39950
#EXTINF:-1 channel-id="631" channel-number="631" tvc-guide-stationid="30017",YES Network
http://{{ .IPADDRESS }}/play/tuner/YESOM~7ec4c3a9-52a4-fc75-7ae3-4c5cc56cc9e8
#EXTINF:-1 channel-id="634" channel-number="634" tvc-guide-stationid="80169",MSG
http://{{ .IPADDRESS }}/play/tuner/MSGOM~d8e66c4b-8fd7-b378-eeec-237da090517d
#EXTINF:-1 channel-id="635" channel-number="635" tvc-guide-stationid="70285",MSG Sportsnet
http://{{ .IPADDRESS }}/play/tuner/MSGSNOM~99c9bc89-9aa5-6a4a-e5b8-f0b6437c9393
#EXTINF:-1 channel-id="639" channel-number="639" tvc-guide-stationid="49603",SportsNet New York
http://{{ .IPADDRESS }}/play/tuner/SNYOM~14d4252a-b378-278a-f51a-c30eb2df9427
#EXTINF:-1 channel-id="640" channel-number="640" tvc-guide-stationid="46817",MASN
http://{{ .IPADDRESS }}/play/tuner/MASNOM~4561b79f-8d5d-82cc-4229-d28b27b4d0c3
#EXTINF:-1 channel-id="642" channel-number="642" tvc-guide-stationid="10271",Monumental Sports Network
http://{{ .IPADDRESS }}/play/tuner/MNMT~4876f881-1191-93f6-a860-d511ce3fa6ab
#EXTINF:-1 channel-id="646" channel-number="646" tvc-guide-stationid="75057",Bally Sports South
http://{{ .IPADDRESS }}/play/tuner/FSSOOM~6b1b1fd0-f99e-21a3-3c9b-4e203159542d
#EXTINF:-1 channel-id="649" channel-number="649" tvc-guide-stationid="89889",Bally Sports Southeast
http://{{ .IPADDRESS }}/play/tuner/FSSEOM~a4d30cc4-b643-f450-edeb-780912f11235
#EXTINF:-1 channel-id="653" channel-number="653" tvc-guide-stationid="96010",Bally Sports Sun
http://{{ .IPADDRESS }}/play/tuner/FSSNOM~c2cb18d4-8522-98ed-5ed7-e82dbe72b713
#EXTINF:-1 channel-id="654" channel-number="654" tvc-guide-stationid="102053",Bally Sports Florida
http://{{ .IPADDRESS }}/play/tuner/FSFLOM~54991b93-7c1e-3469-f8bd-8143a3614564
#EXTINF:-1 channel-id="659" channel-number="659" tvc-guide-stationid="26028",SportsNet Pittsburgh
http://{{ .IPADDRESS }}/play/tuner/SNPTOM~fdc8df0a-27b2-af5c-794f-83c2e5b9ef26
#EXTINF:-1 channel-id="660" channel-number="660" tvc-guide-stationid="11106",Bally Sports Ohio
http://{{ .IPADDRESS }}/play/tuner/FSOHOM~3328cf65-3f83-e0a9-c434-88598604efad
#EXTINF:-1 channel-id="662" channel-number="662" tvc-guide-stationid="50167",Bally Sports Great Lakes
http://{{ .IPADDRESS }}/play/tuner/STOOM~54376de0-5f07-7a27-8aba-b537ad9181d6
#EXTINF:-1 channel-id="663" channel-number="663" tvc-guide-stationid="96250",Bally Sports Detroit
http://{{ .IPADDRESS }}/play/tuner/FSDOM~5c3de28e-b0f5-2318-d1f5-b9b5dbeece65
#EXTINF:-1 channel-id="664" channel-number="664" tvc-guide-stationid="116034",Marquee Sports Network
http://{{ .IPADDRESS }}/play/tuner/MARQOM~d33b3eb7-916a-43b5-ea7c-1c0f246f2032
#EXTINF:-1 channel-id="665" channel-number="665" tvc-guide-stationid="65369",NBC Sports Chicago
http://{{ .IPADDRESS }}/play/tuner/NSCHOM~2a4e8565-4ba2-5608-9915-604ac84ce45f
#EXTINF:-1 channel-id="668" channel-number="668" tvc-guide-stationid="10977",Bally Sports North
http://{{ .IPADDRESS }}/play/tuner/FSNO1MH~3bf48966-a192-91e3-9acb-e272aad57d20
#EXTINF:-1 channel-id="669" channel-number="669" tvc-guide-stationid="16348",Bally Sports Wisconsin
http://{{ .IPADDRESS }}/play/tuner/FSN03HD~ea121788-f35d-2f61-89e9-7c0bf55483a0
#EXTINF:-1 channel-id="671" channel-number="671" tvc-guide-stationid="69825",Bally Sports Midwest
http://{{ .IPADDRESS }}/play/tuner/FSMWOM~7886070f-db0c-eb9c-6d5f-52d1e7fc1e91
#EXTINF:-1 channel-id="674" channel-number="674" tvc-guide-stationid="77744",Space City Home Network
http://{{ .IPADDRESS }}/play/tuner/SCHNOM~43a6c1eb-9080-1c82-84d3-c54e2a96e907
#EXTINF:-1 channel-id="676" channel-number="676" tvc-guide-stationid="108428",Bally Sports Southwest
http://{{ .IPADDRESS }}/play/tuner/FSSWOM~e343d71b-402e-134e-e085-73b8a3d83343
#EXTINF:-1 channel-id="681" channel-number="681" tvc-guide-stationid="44263",Altitude Sports
http://{{ .IPADDRESS }}/play/tuner/ALTOM~9c72b3a5-c4ec-de97-c2ac-9d5f5
Channel number, Gracenote Station ID, Channel Name, Call Sign and Resource ID are all there. If you fed an example of the JSON output from an ADBTuner export, and a matching M3U example from here, AI should be able give you a jq command to make it happen.
Or heck, for that matter, the AI could probably just create the desired M3U for you from the JSON export with an example from above...
I managed to get this set up yesterday. It was fantastic to add all of my channels so easily. As always, I'm relying on my ONN 4k's to do the tuning.
Seeing the recent discussion on this thread reminded me of why I had given up on using ADBT for DTV using my onn 4k boxes. There was the "still watching" hurdle. And the overnight/4hour "deep sleep" issue as well. I'm really glad to see such progress!
Has anyone tested to see what happens if you jump to another app like Peacock, and then back into DTV? It needs to make a stable transition in and out of not just DTV, but other apps as well.
Currently, I'm using @bnhf 's "DirecTV Deep Links" V1.0 config. From a cold start in the morning, I got a 15 second tune. After the DTV apps had warmed up, tuning times are more like 8 seconds. Jumping channels on the same tuner hit closer to 5 or 6 seconds!
I mostly pre-record anything we watch. So all of these tune times are ok with me. I'll take reliability over speed every time. @anon38303228, if you manage to get faster tuning with your config, and it is reliable, that will be a big win for channel surfers.
I have Peacock set up with ADBT and will play with transitioning between apps when I find time later. I'm very hopeful that this is turning out to be a solution for cheap guys like me to stay ahead of the curve. It's especially good if setup is simple, as you have made it through Project One-Click.
I think you did the best you could. DTV app is tricky to use with deeplinks. It's not like YTTV or Sling where a url is just enough really
You're not alone in getting to this point, there's some crazy baked into the DTV Android app.
Honestly, that's pretty danged good! If it's reliable, it rivals the tuning I'm getting from the Roku Tuner Bridge. @anon38303228 , I haven't tried your version of ADBT DTV config yet. I'll set it up for a few channels to compare to Roku today.
Considering @bnhf 's addition of the easy DTV setup to project one-click, this ADBT DTV solution looks to be the front-runner in pulling in the non-TVE DTV channels. Especially for cheapskates like me! The onn 4k boxes are a solid bargain at $20. 4k Plus is $30, and 4k Pro is $45. The Roku devices fall into the same price point. BUT...so far, every single channel needs to be manually input to the Tuner Bridge program.
For me, I already have sets of both devices. Being a "belt and suspenders" guy, I'll keep both setups running, with one up front, and the other as a back-up.
I just applied the config just posted here and it is solid. My android boxes can now easily tune the major services as required.
I didn't believe it when you said..."Alright, I am giving up". If you're like me, once your brain is kicked into the "there must be a way" mode, there's no letting go of it, even when you've had enough.
However, that act of "giving up", often can serve to release you from whatever loop you have been stuck in, and free you to head another direction.
Maybe this one is it!
I just tried your v6.0.0 config with my onn 4ks. I was getting consistent tuning in 10 seconds. I can't remember if I have animations disabled. Thanks for the reminder. I'll double check and try v7.0.0 this afternoon.
EDIT: Animations were enabled when I tested v6.0.0. They must have popped back on during a system update. I'll try v7.0.0 with animations disabled.
